Results 1 to 3 of 3
    ROG Member Array
    Feb 2020
    16
    Armory Crate Has Become Worse Than iCUE
    I thought it was impossible but true.
    To all those that say a reinstall of Windows is the only way to fix most AC issues is the worst advice one can give.
    Especially when the uninstall tool is a joke like AC itself.
    I ran into more issues again with AC, the unistaller did not clear everything out and AC kept giving me the same errors. No way in hell I was going to reinstall windows again becuase of AC.
    I cleaneed out all registry settings, made sure all the services were deleted, services not attempting to be run and cleared out all Asus AC files.
    It finally worked to get AC to install.
    Of course, another issue popped up with the GameSDK Service not installing.
    To the mods and everyone else telling people to reinstall windows, that is a joke and the worst advice that can be given.
    I am going to work on a script to remove AC properly after I am get some food. Been at this crap all day which was nothing but a waste.
    Please ASUS fix AC.
    Asus hardware has been my go-to for so many years and the only ones I really trust at this point. Don't let ****ty softweare ruin it for you,
    Put the time in to make it lean while working properly. Many of us do not care about some freaking virtual pet.
    ROG Guru: Orange Belt Array pndiode PC Specs
    pndiode PC Specs
    Laptop (Model)ASUS G752VL-DH71 Win 11 Pro 21H2
    MotherboardROG Maximus XII Formula
    ProcessorI7-10700K
    Memory (part number)G-Skill F4-3600C19Q-32GTZRB
    Graphics Card #1ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block
    Graphics Card #2ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block
    MonitorLG UltraGear 32GN50T-B
    Storage #1WD Black SN750 1TB
    Storage #2WD Blue 4TB (4 ea)
    CPU CoolerEK PE 360 (Top), PE 240 (Front), and Xres 100 Elite
    CaseROG Strix Helios
    Power SupplyThermalTake Toughpower 1200W
    Keyboard ROG Strix Scope RX
    Mouse Logitech MX Master S2
    Headset ROG Strix Fusion 300
    Mouse Pad Generic
    Headset/Speakers Bose Companion 3 Series II
    OS Windows 11 Pro 22H2
    Network RouterGeneric
    Accessory #1 Corsair ML140 (4 ea), Corsair ML120 (3 ea)
    Accessory #2 ASUS External 16X BLU-RAY Writer
    Jan 2016
    31
    308
    Never used iCUE but:
    Armoury Crate somewhat works with ASUS products. If one wanted a dashboard, they could have installed AI Suite. All the bloatware is not required for RGB control.
    Amoury Crate somewhat works with ASUS products. If one wanted to control 5V RGB or 12V RGB Aura Sync version 1.07.84_v2 works flawlessly, but one does not have control to change the OLED panel on some motherboards. Whereas this was a separate program on previous ASUS motherboards that is no longer available for newer motherboards.
    However, the only reason I am using Armoury Crate and Aura Creator is that I have no control over motherboard OLED display or keyboard LED colors unless I use Armoury Crate and Aura Creator with all the bloatware.
    Anyway, if motherboard OLED display or keyboard LED colors options were included in Aura Sync version 1.07.84_v2 or as a separate software program, I would not be using Armoury Crate or Aura Creator.
    Administrator Array MasterC@ROG's Avatar
    Aug 2014
    223
    2,277
    Please install version 5.4.8.2
    I totally understand reinstalling Windows is a hassle and highly undesirable, but under certain circumstances it saves you time. Getting into the registry and spending time to troubleshoot can often result in more effort, problems and wasted time in the end (most people here have ridiculously powerful rigs capable of reinstalling Windows in less than 30 min). The mods do not know what you've done to the registry, whether your OC is stable, whether you had decided to delete important program files manually. This is precisely the reason why service centers (no matter which brand) will ask for your permission to reinstall. Asking whether you have done so is valuable info when trying to determine your issue. Perhaps you do have the expertise to play with the registry safely, but you must also know that for many - it's risky business.
