nVidia 296.10 crash...HELP
Criton
Hi All,
if i want to open my nVidia Control Panel, or "update" the software, the nVidia make crash wit the message: Microsoft Visual C++ Runtime Library - This application has requested the Runtime to terminate it in an unusual way.
or if i click on the nVIdia Systemtray icon then come the following error message :
Problémaesemény neve: APPCRASH
Alkalmazásnév: nvtray.exe
Alkalmazásverzió: 7.17.12.9610
Alkalmazás időbélyegzője: 4f4e85f9
Hiba – modul neve: nvtray.exe
sorry for the Hungarian message 😛
before i have never seen this error message with this Version of nVIdia.
Any idea?
My System is, Asus G53SX with nVidia 560M 2GB and the nVidia driver version is 296.10
OS : Hungarian Windows 7 Home Premium 64Bit, with Service Pack 1.
G53SX-S1143V BIOS 209
Kingston 16GB 1333 DDR3
OCZ VerteX 3 120 GB SSD - Seagate Momentus 750 GB
Razer Abyssus
21 REPLIES 21
fuzon1337
Hi
Try to downgrade the nVidia driver 285.xx WHQL driver and see if that helps... Many (including me) had issues with the 296.10/16, so try to downgrade and see if that helps 🙂
Asus G73SW-91058V 3D
- Intel Centrino Ultimate-N 6300
- BIOS 205
this problem also affects other people (Asus G users)? Nvidia knows about it?
Razer Abyssus
fuzon1337
Yep, if you go to the nvidia forum, then you can see that other people are haveing issues with the drivers they do release
- BIOS 205
ok, thank for you help 🙂
Razer Abyssus
and what is with the GeForce 301.24 Beta Driver?
Razer Abyssus
Hi folks, I don't reply much here, but driver issues are my biggest pet peeve.
I also had major issues with the 296.10 set. I did a clean install of the 301.24 betas on day of release and haven't had a single problem with them.
I don't normally do a full safe mode sweep like some recommend, but I did here. Uninstalled all Nvidia software, booted into safe mode and manually deleted all Nvidia folders related to drivers, then ran ccleaner on both the system folders and registry, rebooted and installed the 301s along with physx and all else. I've had time to test the following games that I had driver trouble with, on multiple driver sets.
Witcher 2
L4D 1 & 2
Dead Island
Alan Wake
Dead Space 2
AVP 2
Fallout NV
Skyrim
Not one crash or driver stopped responding. As always with this stuff, YMMV.
Nvidias drivers have given me enough grief I'm hoping this helps someone out.
G74SX-NH71 / 2670QM / 560m / 12Gb ram / intel wireless - 6300n / 500Gb seagate momentusXT + WD 500Gb
Boosted_R
Use 295.73 works flawless if you install it properly (used it since it came out without issue)........ ASUS is getting more and more useless and now with officially updating with a horrible driver....... Installed 296.10 and it crashed 20min after....... I have also had many issues with Nvidia drivers, TDR and Aero crashing, but the 295.73 has been great.
GL702VSK / GTX 1070 / M.2 960 EVO
HTPC MINI-ITX / FRACTAL CORE 500 / GIGABYTE GA-AB350N / GTX 1050 Ti Windforce OC 4G / RYZEN 5 1600 3.9GHz / M.2 960 EVO / G.SKILL Ripjaws V Series 3200MHz
OLD
ASUS G74SX-XC1 / INTEL 7260 AC / Samsung 850 PRO / TUNIQ TX-4 / BIOS 203 / 335.23
i have now see, Asus has released new driver for nVidia ? Version V8.17.12.9616 then that is 296.16?
This driver is better then the nVidia original (296.10) driver? because, the 296.16 i cant find on nvidia.com
Razer Abyssus
Yes, I also believe that's the 296.16 version that Marshall@ASUS linked here in the forum.
I'm currently using it, and it's stable on my G74.
ASUS G74SX-3DE
