01-21-201107:23 PM - last edited on 03-05-202407:54 PM by ROGBot
:mad:any one else have this issue ? non compatible rom file for this bios update???? M4A89GTD-PRO-ASUS-1801.ROM is flah im trying to update from1606 to 1801
Are you using the Windows flash utility? I found that the last update I tried to do I needed to let the updater update itself first. If you allow it to check for updates on the internet after that it should find all of the most up-to-date ones that are compatible.
Have u tried to set the bios to defaults. This board is very picky about bios updating. U need to set the bios to defaults before flashing. I owned this board for a year before selling it and moving to AM3+.
I have ripped out some hair with some M4A series boards... then I updated one to a M5A Series AM3+.... WOW Awesome board.:) Best of Luck Lemon123 and Welcome New ROG Forum Member
You joined in January and this is your first post? What took us so long? Sorry..
Glad to be here JJ sent me over here. Thought I could be of some help While i am here . while I do not work for ASUS I know alot about AMD. I have been using AMD CPU's since the 486 days which was 15 years ago. I started out when I was 16 years old and have been at it since and no real reason to let up now. But occasionally I get stumped on the new stuff like Digital VRM settings and what each setting does. Which I am like lost in that DEPT. If you need any help with something please ask And I will try my best to answer it for you .
Fantastic....you said all we needed to know when you said JJ sent you..quite a reference. This member team grows stronger everyday....no wonder the other board makers.. (are there any left)....scratch and claw for no.2..... This keeps No.1 out of reach for them...and always will. Good to know you, John Chambers.
Just be aware of the dates on these threads guys. This user hasn't even logged in since January. I think if he hasn't flashed his BIOS by now he probably isn't still trying.
