Results 1 to 4 of 4
05-02-2012 11:23 AM #1ROG Enthusiast Array
- Join Date
- Dec 2011
- Reputation
- 10
- Posts
- 36
BIOS UPDATE! how to do it Using Easy Flash..
i want to update my BIOS but i dont know how.please show a step-by-step procedure on how to update using EasyFlash on BIOS.
05-02-2012 02:39 PM #2
Hi
Which notebook do you have? Go to support.asus.com then search for your model and you shoud find the latest BIOS update.
***IMPORTANT DON'T UPDATE YOUR BIOS UNLESS SOMETHING IS WRONG AND CAN GET FIXED BY FLASHING THE BIOS***
Go to this thread http://rog.asus.com/forum/showthread...untry=&status= and download the pdf file. @BrodyBoy made this guide about how to flash the G74, but it's the same procedure for all notebooks.Asus G73SW-91058V 3D
- Intel Centrino Ultimate-N 6300
- BIOS 205
11-14-2012 06:18 AM #3New ROGer Array
- Join Date
- Oct 2012
- Reputation
- 13
- Posts
- 2,441
Hi, 1. go to asus support website to search what model do you have.
2. download BIOS and save to USB disk
3. press F2 into BIOS
4. select ezflash
5. select your BIOS locate
11-14-2012 11:20 AM #4New ROGer Array
- Join Date
- Mar 2012
- Location
- In the Orion arm of a spiral galaxy in the Local Group...
- Reputation
- 176
- Posts
- 4,761
@fuzon1337 is correct, if your system is running fine, don't risk a flash. But like they said, use EZ-Flash from the BIOS, not the Windows BIOS destruction utility. (Not its actual name, changed to better represent what it too often does).
