05-10-2012 09:52 AM - last edited 3 weeks ago by ROGBot
05-10-2012 04:17 PM
05-11-2012 12:47 PM
05-11-2012 02:15 PM
tech_droid wrote:
This has to be a VIA driver issue of sorts. I fussed with the audio for a good amount of time last night and got different results. The LFE controls seems to need an extra step to get the sub woofer to vary in it's pitch.
05-11-2012 04:16 PM
05-11-2012 04:55 PM
05-11-2012 05:31 PM
tech_droid wrote:
Have you tried downloading the drivers directly from VIA yet? I'm going to give that a try when I get home from work tonight.
05-11-2012 05:39 PM
05-11-2012 08:41 PM
Speakers
After a long time spent trying to configure the speakers of the test model, we came to the conclusion that our sound system had a few bugs. We contacted Asus and they told us that it was probably due to the driver of our precursor model.
The subwoofer only works when we set the speakers to “2.1 channels” in “VIA HD Audio Deck” (advanced mode). Sadly, with this setting, the subwoofer delivered the bass and all the other tones as well. Result: playback heavily based on the left side.
In addition, the volume is quite high even with low settings. This issue could be somewhat corrected when we dropped the volume of the subwoofer (via “Audio Deck”). A little tuning made the sound output of the G75 really good but it could not reach the level of the Toshiba Qosmio X770 or the MSI GT70 (TOSHIBA PA-1181-02 adapters).
Asus should check the audio software of the laptop and remove any bugs. We will test the finished model again (when it is launched).
07-25-2012 12:38 PM
