Results 1 to 4 of 4
    snowful
    Guest
    P8P67 pro problem?
    I have recently purchased a new rig:
    I5 2500k
    P8P67 pro
    Kingston HyperX 2x4G
    Msi gtx 570
    cosair hx750w
    When I boot up the computer it shuts itself down immediately then boots itself up again.
    This happends everytime I turn on my computer. Is this normal?
    Also I'm using logitech z-5500 as my speaker pluged into optical. When the computer is on I hear buzz sound from the speakers. Nothing like this happend before on my previous rig.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    329
    7,927
    The double booting has happened to me before as well on different hardware. I'm not sure if it is the PSU or the motherboard that causes it though. It never really caused me any problems so I just didn't bother to figure it out.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Jmin
    Guest
    I have the same issues. It happens with my speakers. And my headphones.
    I think the double boot thing might be something to do with the memory. I am using G.skill ripjaws X 12800CL7D-8GBXH
    ROG Enthusiast Array
    Apr 2010
    15
    29
    enter UEFI BIOS -> go to ‘Advanced’ tab -> go down to ‘APM’, press Enter -> enable the “Power on by PCIe.” function
    This should fix ur problem ...
Similar Threads
  1. Ah crap... Did I buy the wrong memory for a p8p67 pro ? Help please.
    By Shelledfade in forum Other Series Motherboards
    Last Post: 03-30-2011, 12:51 AM
  2. P8P67 and ATAPI devices
    By Daybee in forum Other Series Motherboards
    Last Post: 01-21-2011, 07:40 PM
  3. Using two GPUs on P8P67
    By xbonez in forum Other Series Motherboards
    Last Post: 01-18-2011, 07:20 PM
  4. P8P67 Series Overview!
    By Mason@ASUS in forum Other Series Motherboards
    Last Post: 01-10-2011, 12:03 AM
  5. ASUS P8P67 WS Revolution Motherboard Pictured
    By ottoyu34 in forum Overclocking & Tweaking
    Last Post: 12-10-2010, 12:06 AM
