Results 1 to 10 of 10
    ROG Member Array
    May 2012
    14
    The G75 subwoofer - will it be fixed?
    The G75 subwoofer plays all the frequencies, which makes the sound pretty adequate. The sound would me much better if only the bass sounds (below 150Hz) would be directed to the subwoofer.
    So the question to Asus is: Is there going to be a fix to this, and if so, how soon? Or is this a permanent situation???
    Ps. Could an owner of a G75 test how low the subwoofer can go? You can test it really easy with this: http://wn.com/Ultimate_Bass_Test__10...__MY_BEST_EVER
    My current laptop goes to about 64-63Hz and after that it's just a whirring sound.
    ROG Member Array
    May 2012
    11
    In the strict sense of the word, the g75 subwoofer isn't actually a subwoofer given that it plays a wider range of frequencys than it should, therefore the information provided by ASUS would be misleading as long as it still unfixed. And apart from the posible legal consecuenses that this may produce, for me ASUS has affected its reputation. Im not saying the g75 is a bad product, overall is excellent, but I am being much more careful next time I buy a laptop. I really wish ASUS fix this problem, or at least be honest and state its position.
    Asus G75VW-BBK5
    Asus G53SW Old Laptop
    ROG Guru: Green Belt Array
    May 2012
    46
    615
    Quote Originally Posted by elyasib View Post
    Marshall from asus has already noted ( several times ) that they are looking into the problem.
    Let's remember please that this series of machines is fresh out in the marketplace and any fixes/updates will take some time to get tested before being made available.
    ROG Member Array
    May 2012
    11
    Quote Originally Posted by john_from_ohio View Post
    I guess I was a little rude, let's wait then...
    P.S. btw do you guys happen to know any good usb audio card, and if they really worth the investment.
    Asus G75VW-BBK5
    ROG Guru: Orange Belt Array
    Jan 2012
    317
    well i got all the way to the 1hz. on my sub
    G75vw DS71
    3610QM I7
    16GB Ram 1600mhz
    750GB+120GB(patriot pyro)
    Nvidia gtx 660m
    Purple Keyboard mod
    Proud Owner of a GTX 660ti DC-II
    ROG Member Array
    May 2012
    14
    Quote Originally Posted by Holy View Post
    Umm, I doubt that. Could someone do the test, please?
  7. #7
    ROG Member Array
    Aug 2012
    20
    I just bought a new Asus G75 and I've experienced this problem with subwoofer. I've tried to adjust something using the "VIA HD Audio Deck" without any success.
    I feel the following issues:
    1. The volume of the subwoofer is always max;
    2. There are higher frequencies, cause of saturation.
    I think they should update drivers and the application "VIA HD Audio Deck". The hardware works fine IMO, but they skipped some important small adjustment.
  8. #8
    Jul 2012
    48
    691
    New driver puts LFE volume a bit under speakers.
    ASUS Xonar U3 is worth a test. Unless you want to go HI-FI and then the game changes a lot.
  9. #9
    ROG Guru: Green Belt Array mrwolf's Avatar
    Jun 2012
    21
    657
    What ive done a for a temporary fix ( not really a fix but makes the sound a bit better ) is if you right click on speakers and go onto sounds in from the taskbar, right click on the speakers - properties - levels and then put your volume to max. Then set the monobass to half that and you should get clearer sound coming primarily from the middle rather than just the sub masking everything..
    Hope they sort it out soon tho
  10. #10
    ROG Guru: Yellow Belt Array Ayman PC Specs
    Ayman PC Specs
    MotherboardAsus Maximus IV Formula Z270
    ProcessorCore i7-7700K
    Memory (part number)Corsair Vengeance LED 32GB / 3000MHz
    Graphics Card #1Asus GTX 1080
    Sound CardCreative Sound Blaster Recon3D
    MonitorAsus ROG SWIFT PG278Q
    CPU CoolerCorsair H110
    CaseCorsair Obsidian 750D
    Power SupplyCorsair AX860i
    Keyboard Razer Blackwidow Chroma
    Mouse Razer Mamba Tournament Edition
    Headset Razer Kraken Pro
    Mouse Pad Razer Firefly
    Headset/Speakers Creative GIGAWORKS T40 SERIES II
    OS Win10 Pro x64
    Ayman's Avatar
    Jun 2011
    14
    141
    As for me i removed the VIA driver software and i update the driver from VIA folder the the sub woofer is off now just using the 2 speakers and i can use the headset without any problem.
    Case: Corsair Obsidian 750D.
    CPU: Core i7-7700K.
    Board: Asus Maximus IV Formula Z270.
    VGA: Asus Strix GTX 1080.
    Ram: 32GB Corsair VENGEANCE LED 3000MHz.
    CPU Cooler: Corsair H110.
    PSU: Corsair AX860iW.
    SoundCard: Creative Sound Blaster Recon3D PCIe.
