Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    ROG Member Array sate200's Avatar
    May 2012
    14
    Project Sate200 ROG
    SYSTEM AND WATERCOOLER:
    ASUS RAMPAGE IV EXTREME+(BLOCK RP4 KOOLANCE)-INTEL CORE i7 3930K + EK SUPREME-HF(EN) - 16GB G.SKILL RIPJAWS Z 1866MHZ - 3X ATI 7970 4GB+EK-7970 BLOCK- Corsair AX1200 - 2 X SSD CORSAIR FORCE 3 GT 120GB (RAID 0) - 2 X WESTERN DIGITAL 1,5TB - OBSIDIAN 700D - COMPRESSION BITSPOWER - 3x RAD 360 KOOLANCE - RAD Black Ice Xtreme 3 X-Flow Radiator 360-RAD XSPC RX240 - 3X PUMPS KOOLANCE 450S+ RESERVOIR KOOLANCE 450/S-EK TOP 140.
    LOT OF PICTURES!!!
    [BASUS RAMPAGE IV EXTREME+(BLOCK RP4 KOOLANCE)-INTEL CORE i7 3930K + Koolance 380i - 16GB CORSAIR DOMINATOR PLATINUM 2400Mhz - 3X ATI 7970 4GB+EK-7970 BLOCK- Corsair AX1200 - 2 X SSD OCZ VERTEX 4 128gb (RAID 0) - 2 X WESTERN DIGITAL 1,5TB - LD-V8 - COMPRESSION BITSPOWER - 2 x RAD ALPHACOOL XT45 480mm - 1 x RAD ALPHACOOL UT60 480 - 3X PUMPS KOOLANCE 450S - Dock EK D5 White- RESERVOIR KOOLANCE RP-452X2 - RESERVOIR EK RES-X2 250 Advanced [/B]
    May 2012
    14
    May 2012
    14
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    199
    8,359
    WOW, that's a strong built! And a lot of cooling capacity...
    Do you have a dual loop, or that top radiator is part of a single loop containing the external huge radiator too?
    Just from curiosity: You're not using the side panel anymore? I mean, that plate closing the bottom PSU area of the case is awesome, but you still can put on the side panel?
    May 2012
    14
    Quote Originally Posted by Zka17 View Post
    Yes, I have a dual loop, the top radiator, loop cpu and motherboard, the rad box with 3x rad´s 360, on loop of vga!!
    unfortunately, after I put aa sheet of acrylic, not able to close more! however was very nice!
    thanks man, sorry for my english, in Brazil is very dificult the practice of language!!!
    Mar 2012
    199
    8,359
    No problem with your english, mate - I can understand (it's not my first language either )
    Also, I don't see a problem for not being able to put back the side panel - except that your top radiator may get stuffed with dust... but the other one could too, so just check them time by time... Or, and it's just an idea, you could mount a transparent acrylic pane above that bottom one...
  7. #7
    AntiMatter Guru ROG Array chrsplmr's Avatar
    Jul 2011
    295
    6,113
    WOW ... i am blown away .. i need a shower....... thnx.c.
  8. #8
    ROG Enthusiast Array
    May 2012
    14
    61
    Wow! Absolutely Amazing! Looks Badass, nice custom nameplate too!
    Asus G75VW-NS72
    Intel Core i7-3720QM 2.6GHz
    16GB DDR3 1600MHz
    750GB 7200RPM + 256G SSD
    Nividia Geforce GTX 670M 3G GDDR5
    Blu-ray Burner
    "Right...very creepy. Forget I asked."
    -Alistar DAO
  9. #9
    TeamROG Array
    Mar 2010
    18
    260
    Wow amazing build. You should have another panel custom cut for the top with a shaped window maybe the ROG logo
  10. #10
    ROG Guru: White Belt Array
    May 2012
    12
    90
    Holy... This build has blown me away! This is amazing, beyond words.. Well done
