Page 4 of 8 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 31 to 40 of 71
  1. #31
    ROG Guru: White Belt Array
    Sep 2011
    86
    Quote Originally Posted by Arne Saknussemm View Post
    I7 3820 maximum multiplier e 43.... 4.7 GHz = 125 BCLK x 38 multiplier Turbo ratio....by all core.
    CPUPLL 1.8.
    Inizia con questi
    Prima di mandarlo oltre 4,3 meglio controllare le sue temperature,il cpupll a 1,8 serve solo ad aumentare le temperature,io a 1,5 sono stabile a oltre 5,0Gz sotto linx,preferisco tenere il daily a 4,9,per rimanere con v-core sotto 1,4 stabile sotto linx.
  2. #32
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    499
    13,601
    Quote Originally Posted by sisco View Post
    Naturalmente! Volevo solo spiegare come funziona i73820.
    CPUPLL forse siete fortunati Intel dice 1.8......
    La prima cosa da fare è mettere Ram correttamente e dopo overclock
  3. #33
    Sep 2011
    86
    Posso assicurarti che con il cpupll,non è fortuna,perchè anche con il mio precedente 3930K,lo tenevo a 1,5 a 4,7 in daily,come molti altri amici con OC più o meno spinti,intel in effetti dichiara un valore tra 1,719 e 2,0,ma dalle diverse esperienze che ho avuto su questa tensione sbaglia.
  4. #34
    ROG Enthusiast Array levis501's Avatar
    May 2012
    44
    CPUPLL 1.8.
    Inizia con questi
    grazie, provo e ti faccio sapere
  5. #35
    May 2012
    44
    Cambia i valori seguenti:
    1 screen:
    Turbo ratio=by all core
    2 screen:
    core ratio limit=43(hai solo un valore adesso)
    clock cen filter=enable
    memory frequency=1600
    3 screen:
    cpu core voltage=1,3(da limare probabilmente)
    4 screen:
    tutto bene
    5 screen:
    cpu load line calibration=medium
    cpu current capability 120%
    Vcore mos volt.control 7V
    Cpu power phase control=optimized
    Vccsa load line calibration=medium
    Vccsa current capability 110%
    6 screen:
    Cpu vtt switching freq=1.3x
    pch 1.1 switching freq=1.3x
    7 screen:
    inserisci manualmente i valori primary timing al posto di auto come li leggi di fianco.
    Screen da 8 a 12,lascia tutto com'è.
    Come pensavo i valori erano tutti sballati,per ora prova cosi,cioè a 4,3(limite del tuo moltiplicatore),poi controlleremo le temperature sotto stress(sei sempre ad aria,quindi prima di salire oltre,meglio controllare),prova e se sei stabile,proviamo a salire(cosa sconsigliabile ad aria),o ad ottimizzare.
    provo anche con i tuoi valori e ti faccio sapere. ma dopo posso metterlo sotto stress con il programma OCCT, l'ultima versione, o con altri programmi che potrai suggerirmi? grazie
  6. #36
    Sep 2011
    86
    Quote Originally Posted by levis501 View Post
    I valori che ho postato mettili per primi,perchè regolano le fasi di alimentazione e i timing delle ram in modo manuale,sistema decisamente meno soggetto a errori durante il funzionamento.
    Rimani a 4,3 e testa con linx(0.64)_10.3.7.012,è importante che windows 7 abbia installato il SP1,ovviamente mentre testi linx(settando la memoria a 7gb),lancia anche Real Temp per tenere sotto controllo la temperatura dei singoli core e se raggiungono gli 80°,ferma linx,perche cominci ad andare in zona deleteria(mio parere).
    Se riesci a superare 10/15 cicli senza problemi,allora in base alle temperature massime raggiunte,si può tentare di andare oltre aumentando il blck,farlo prima è sconzigliabile per 2 motivi:
    1 rischi di andare troppo oltre con la temperatura
    2 variando il blck,varia anche il bus della ram,che nel tuo caso potrebbe diventare la causa di instabilità,sviando le vere cause dei BSOD.
  7. #37
    Apr 2012
    499
    13,601
    OK, interessante, potrei provare a regolare con la mia
  8. #38
    May 2012
    44
    ok! sto provando in questo momento con i due programmi che mi hai suggerito. appena finisce i cicli ti invio i dati.
    grazie
  9. #39
    May 2012
    44
    ecco i miei dati con i programmi suggeriti. il primo link è durante il test, il secondo è a fine test.
    http://imageshack.us/photo/my-images/196/test1jy.png/
    http://imageshack.us/photo/my-images/855/finetest.png/
  10. #40
    May 2012
    44
    ciao, anche tu stai provando con questi valori? controlla anche tu i miei test e dimmi cosa ne pensi.
    ciao
