Results 1 to 5 of 5
    ROG Member Array
    Jun 2012
    9
    Need help with Maximus V Gene Raid
    I've just bought a Maximus V Gene and setup a raid 0 with 2 ssds, everything look fine, but 1 problem. Everytime the PC boot up, it always show a screen and wait about 3 secs to press Ctrl+I to setup raid, I have setup raid already and now, I don't need that screen anymore. Is there any way to hide/disable that screen? It delays my boot and look so ugly
    Anyone know how? thanks
    Sorry for my bad English
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    164
    7,454
    With the RAID ROM enabled the menu has to appear AFAIK. Best workaround is to use S3 sleep and not worry about powering up from cold. With an ErP compliant PSU, power consumption will be less than 1W in standby :P
    ROG Member Array
    Jun 2012
    9
    Cool
    Quote Originally Posted by Raja@ASUS View Post
    Really? so that screen cannot be turn off, right? ok, thanks you for giving me useful info about S3 sleep state. I'll try.
    Apr 2011
    164
    7,454
    Check in UEFI if there is an option to disable the BOOT ROM. I don't have the board in front of me so cannot check right now. If there is not then try S3, will save you lots of POST~BOOT time.
    ROG Member Array
    Jun 2012
    9
    Ok, thank a lot. I'll try searching around the UEFI, this is my first time playing with ROG mobo
Tags for this Thread
