Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    ROG Guru: Yellow Belt Array xmanrigger PC Specs
    xmanrigger PC Specs
    MotherboardAsus Rampage IV Formula
    ProcessorIntel i7-3930K
    Memory (part number)CMD16X3M4A2400C10
    Graphics Card #1EVGA RTX 2070 Super /HeatKiller IV
    Sound CardO/B
    MonitorDell Ultrasharp 27"
    Storage #1Samsung 1TB
    CPU Coolerwatercool Heatkiller Rev.3.0
    CaseAZZA Genesis 9000B-W
    Power SupplyCorsair AX1200i
    Keyboard Logitech G15
    Mouse Logitech G502 Hero
    Headset/Speakers logiteck Z-5500 5.1
    OS Win10 64
    Mar 2012
    30
    246
    ROG G75V - 660M does not spool up
    Hey guys, just got this new lappy and cant figure out why the GTX660M will only run at 405mhz. I ran 3DM11 and score P2546. That is pathetic. A S1156 i5 and a GTX460 kicks the **** out of that. The 660M isnt hitting full speed. I have Power4Gear set to High Performance. Also, whats up with Asus Live Update? It doesnt seem to do anything.
    EDIT: I was just playing a movie on the G75V and noticed it is very funky. If 2.1 sound is enabled, audio sounds as if it only comes from left channel. If set to 2.0, sound is barley audible.
    GUTS: Rampage IV Formula (4004) / Intel 3930K / 16GB Dominator Platinum 2400mhz / Samsung 1TB SSD / EVGA RTX 2070 Super / Corsair AX1200i PSU / Genesis 9000B Case
    WATER: Watercool HeatKiller - CPU / Watercool HeatKiller IV - GPU / 1X XSPC RX240 rad / 1X EK Coolstream 480 rad / XSPC Photon Rez / D5 Pump / DISTILLED WATER + Silver Coil
    ROG Enthusiast Array
    May 2012
    14
    61
    I thought the 660M ran at 835MHz? As for the Asus Live Update, pretty much everyone reccommends you uninstall that as it doesn't work properly.
    Asus G75VW-NS72
    Intel Core i7-3720QM 2.6GHz
    16GB DDR3 1600MHz
    750GB 7200RPM + 256G SSD
    Nividia Geforce GTX 670M 3G GDDR5
    Blu-ray Burner
    "Right...very creepy. Forget I asked."
    -Alistar DAO
    xmanrigger PC Specs
    Sound CardO/B
    OS Win10 64
    Mar 2012
    30
    246
    Quote Originally Posted by Brian_ROG View Post
    You thought right, except it wont. i have the latest Chipset and nvidia driver installed, downloaded from Asus support. Why isnt a driver for the 660M available at nvidia.com?
    May 2012
    14
    61
    I don't believe there has been a driver update for the 600M series of cards yet. I have the 670M and am running version 290.69, which is what my laptop came with. Was your card working properly before you downloaded from Asus Support? I'm not really sure what could be the issue...maybe somone will chime in on the situation
    Asus G75VW-NS72
    16GB DDR3 1600MHz
    Blu-ray Burner
    -Alistar DAO
    xmanrigger PC Specs
    Sound CardO/B
    OS Win10 64
    Mar 2012
    30
    246
    The driver I dl'd from Asus is 8.17.12.9644. Not sure what previous driver was or if it worked because I updated Win7 and drivers right out of the box. Since when does anyone use drivers from CD or moldy drivers from factory install?
    There are new drivers for 600M series cards. But it only applies to a select few. I tried the driver and it wont install with 660M. Actually, there isnt a driver listed period at nvidia for a 660M card. Nice.
    ROG Guru: Orange Belt Array
    Jan 2012
    317
    Thats true for the 640m 650m 660m 670m and 675m.
    this issue is the first ive heard mine likes to go down to 270 while doing nothing but it shoots right up as soon as i start to do anything that it can help with.
    G75vw DS71
    3610QM I7
    16GB Ram 1600mhz
    750GB+120GB(patriot pyro)
    Nvidia gtx 660m
    Purple Keyboard mod
    Proud Owner of a GTX 660ti DC-II
  7. #7
    xmanrigger PC Specs
    Sound CardO/B
    OS Win10 64
    Mar 2012
    30
    246
    It does appear to speed up when playing BF3, as BF3 looked good and frame rates were good. But it wont hit full speed running 3DM11. 405mhz is all it will do.
    Another thing I noticed is that this lappy is hardly worthy of the ROG designation. Either that, or ROG dropped the standards immensely. Where is the overclocking ability? Non-existant in BIOS. The BIOS for that matter is pathetically lame for a ROG. Hardly an 'enthusiast' machine. This lappy is no different than any other of same CPU class. Actually, inferior to. It was however, priced decently. Had there been a DELL with same specs at the store, that is what I would have gone home with. Dont get me wrong. I am not here to bash Asus or ROG. Just wondering how this machine managed to garner the ROG designation. Please tell me what is so special about it to warrant being in the ROG line-up.
  8. #8
    ROG Guru: Gold Belt Array dstrakele's Avatar
    Sep 2011
    89
    4,437
    It's got the stealthy black rubberized coating and the fake exhaust port on the left side. Really - what more do you need?
    G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
  9. #9
    Jan 2012
    317
    Xman. you cannot overclock the ivy bridges unless there an extreme. it was the same for sandy bridge. its also the fact that its made by asus lol.
    G75vw DS71
    3610QM I7
    16GB Ram 1600mhz
    Nvidia gtx 660m
    Purple Keyboard mod
  10. #10
    xmanrigger PC Specs
    Sound CardO/B
    OS Win10 64
    Mar 2012
    30
    246
    Quote Originally Posted by Holy View Post
    HELL YA you can oc a Sandybridge! Ask me or many others how to run a 2600K at 5106MHZ. Or are you referring to mobile CPUs? I believe many of them can be overclocked also.
    Again, not here to bash. Just find it odd that this lappy is in ROG lineup. I have owned many ROG motherboards and there was always something or a bunch of things that made it stand above others. I just dont see that here. It so far has met expectations for what it is, other than the 3DM11 issue.
    And back to the issue. Anyone else have this happen with a 660M?
