Newegg.com has a lot of choices for headsets. Did you want Bluetooth or RF Headsets?
Creative sound blaster headset: They are $125, not sure how much you want to spend.
http://www.newegg.com/Product/Product.aspx?Item=N82E16826158155If you want a connected headset you could get the Asus Vulcan ROG headset...looks pretty sweet, too bad its not wireless.
http://www.newegg.com/Product/Product.aspx?Item=N82E16826785024Anyway you can narrow your search on newegg to wireless sets or whatever you want. I usually buy all my electronics through them and always have great service and fast delivery. I can't stand going into a Best Buy, which is why I never do!
Good luck finding something and safe travels!
Asus G75VW-NS72
Intel Core i7-3720QM 2.6GHz
16GB DDR3 1600MHz
750GB 7200RPM + 256G SSD
Nividia Geforce GTX 670M 3G GDDR5
Blu-ray Burner
"Right...very creepy. Forget I asked."
-Alistar DAO
