06-09-2012 06:53 AM - last edited on 03-06-2024 03:26 AM by ROGBot
06-09-2012 07:53 AM
06-09-2012 08:29 PM
PILGRIM wrote:
Hi there. Is your model the G74SX? When you attempted to recharge the 3D glasses
with the USB cable, did you see if there's a blinking orange light near the mini USB port
of the glasses? If there's that blinking light, it means your glasses is recharging.
Wait until the blinking light turns green.
ADDENDUM: If the 3D glasses are recharged, try to do the following:
-Go to nVidia Control Panel > Stereoscopic 3D > Setup Stereoscopic 3D >
(click) enable stereoscopic 3D > stereoscopic 3D display type > ASUS 3D Vision Laptop > Apply.
-Go back to nVidia Control Panel > (click) Run Setup Wizard >
(Configure the 3D glasses with the laptop, turn on glasses and wear them,
you will be asked to do several tests in here. Click the series of "next" until setup is finished.)
-(click) Test Stereoscopic 3D > (Resolution is at 1920 x 1080, Antialiasing is off,
Refresh rate runs better in 3D in 120 Hz) > Close.
If all tests are successful, you should be able to use 3D Mode on your laptop.
06-10-2012 05:05 AM
mcraw82 wrote:
but the problem is the 3D glasses will never but fully charge, it kept blink amber after 4hours and still cant be turn on.
03-25-2013 10:50 AM
03-25-2013 10:27 PM
Atarbrest wrote:
I have G53SX-IX094V
what should i do if I can't choose the "stereoscopic 3D display type" because of after enabling stereoscopic 3D is running Setup Wizard, where is no Glasses with IR built-in emitter. may be I need any IR driver or display driver except nVidia's?
07-31-2014 12:29 AM
03-10-2015 05:29 PM
shakk wrote:
have you found a solution for the problem ?
