Results 1 to 5 of 5
    hacc09
    Guest
    GTX 460m Downclocking on battery mode
    Hi, new to these forums if that makes any difference.
    I bought a G73JW-3DE a couple weeks ago and I noticed that the video card downclocks itself on battery power. I goes from 675mhz down to 203mhz and does not increase when an 3d intensive program is running.
    My question: Is there a way to disable that on battery power anyhow? I've tried every fix I can google to change the powermizer registry settings and it is still not fixed!
    Just kind of defeats the purpose of being a "portable" gaming computer if you have to have it plugged in to perform.
    Other than that, I'm loving this thing do death!
    Thanks in advance,
    Andy
    TeamROG Notebook Member Array Chastity@ASUS's Avatar
    Oct 2010
    18
    1,334
    Yes, you need to disable PowerMizer in the driver's registry settings to disable throttling on battery power. I don't know if this info is current: http://forum.notebookreview.com/gami...ideo-card.html
    Kicking Ass Since Today
    hacc09
    Guest
    Thanks for the reply, but I've tried that program already, I've also tried manually editing the registry to several peoples suggestions. None of them work! It's irritating me.
    If anyone has any suggestions on what to try, I'd be willing to.
    davidcwy
    Guest
    of course it doesn't work, the battery is only 78W while the AC is 150W. The videocard need nearly 75W, so it has to downclock to keep working, I want to edit the bios so that the core videocard can work.
    ROG Guru: Orange Belt Array jorlanm's Avatar
    Apr 2011
    313
    I like your spec...did you get that from me? Hehe same typo...anyway does the 2870 run hotter? Does the cooling fan sufficient wnough to handle it?
    -ASUS ROG G73SW-3DE-
    -Intel Core i7-2630QM Mobile Quad Processor
    -Intel HM65 Express Chipset +ICH10
    -17.3" 1920x1080 120Hz Anti-Glare Matte Screen
    -nVidia GeForce GTX 460m 1.5GB GDDR5 VRAM
    -nVidia 3D Vision Active Shutter Glasses
    -Creative EAX Advanced HD 5.0
    -THX TruStudio
    -8GB DDR3 1333MHz RAM (Max 32GB)
    -2x500 Seagate Momentous XT Hybrid HDD
    -Blu-Ray 4x Burner
    -Logitech Performance MX Darkfield Laser Mice
    -Microsoft Windows 7 Ultimate
    -XBOX360, PS3, Wii
Similar Threads
  1. [Problem]Laptop Toggles from AC/Battery mode all the time
    By Smeakys in forum G Series Gaming Notebooks
    Last Post: 05-23-2014, 02:11 PM
  2. G73JH - Right fan cooling at 100% all the time, even on battery
    By tsfdeymos in forum G Series Gaming Notebooks
    Last Post: 05-24-2011, 04:51 AM
  3. GOt my g73 2 hours ago, battery question
    By Xentec6 in forum G Series Gaming Notebooks
    Last Post: 02-17-2011, 08:14 PM
  4. G73JW A1 Battery Mode/Graphics/FPS Issue
    By Optimo in forum G Series Gaming Notebooks
    Last Post: 02-14-2011, 05:17 AM
  5. Replies: 2
    Last Post: 12-18-2010, 07:19 AM
Tags for this Thread
