Results 1 to 10 of 10
    ROG Member Array
    Jun 2012
    14
    Faulty Cards: GTX670 DC2 TOP
    Hi there.. maybe you that are in direct contact with Asus can make something...
    I'm experiencing a lot of troubles with my STOCK new GTX670 DC2 TOP and I'm slowly finding out lot of threads concerning crashes of STOCK cards as mine one.
    With "STOCK" i mean "without any extra OC" as "out of the box". These cards are OC-ed by default.. so you'll expect that they behaves perfectly "out of the box"..
    They do not.
    Crashes with most games in few seconds/minutes and they don't even complete a full loop of any benchmark software (Unigine, 3DMark11..)
    The most frequent is: "D3D11AppWindow::swap_window(): device removed"
    Everyone is RMA-ing cards back to the retailer.
    Can you - sorry, i meant "Can we" - here at ROG do something with ASUS to prevent this?
    Here you have some links for further informations:
    http://forums.nvidia.com/index.php?showtopic=229531
    http://vip.asus.com/forum/view.aspx?...Language=en-us
    Intel i7-3930K C2 | Asus P9X79 DELUXE | Asus GTX670-DC2T | G.Skill RipjawsZ F3-17000CL9Q-16GBZH 2133MHz | Corsair H100 | 1TB WD Caviar Black | 64GB Samsung 830 SSD | Corsair Carbride 500R White Edition
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,726
    The good news is that there haven't been any TOP cards in stock anywhere that I've seen here in the US. Hopefully the next batch is better. Are they still in stock where you live?
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Member Array
    Jun 2012
    14
    I don't really know.. I usually buy directly from the stock and i saw it the first time a couple of weeks ago and it was restocked almost twice (20+20 i suppose)
    let's see..!
    ..the problem is that I find quite sad to choose a default overclocked card ( at a overclocked price.. ) to underclock it to a base frequency to stop it crashing continuously after 10 secs of benchmark.. :/
    ROG Member Array
    Jun 2012
    14
    Here's the screen of my Haven crash..
Name:	haven crash.jpg
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,726
    Quote Originally Posted by KhelSyS View Post
    I agree. I was only saying that I hope the cards are out of stock because they are fixing the problem before they ship more. Yours is still going to require RMA though.
    ROG Enthusiast Array
    Sep 2011
    15
    51
    1. Increase the fan at 70%
    2. Increase the voltage to the max.
    3. Test again and report back.
  7. #7
    ROG Guru: Yellow Belt Array nadof1's Avatar
    May 2012
    210
    Mine works flawlessly, there seems to be a link between the card and gpu tweak uninstall it and then try and see if your games crash.
    I never installed gpu tweak I use msi afterburner.
    ittle OG
    Maximus VI Impact - I7 4770k - GTX 780 DC2OC
    Trident X 2400 2x8Gb - Samsung 840 500Gb - CM120 Elite
    Corsair Ax860i - H90 2x CF-V14HP
  8. #8
    ROG Member Array
    Jun 2012
    14
    Quote Originally Posted by psyside View Post
    I know that there are few workaround, thank you so much anyway
    The problem, as i mentioned before, is that an overclocked and BINNED ( I read that the process of selecting the best cards is named this way ) card paid way more than a reference one DOESN'T HAVE TO crash out-of-the-box!
    I should go for RMA but i read that now is like a lottery: you have few chanches to get a perfect one.
    Someone RMA'd them two times and still no luck :/
    I think I should tweak it and wait few months.
    Anyway, unistalled GPUTweak and installed PrecisionX from EVGA. Let's try also Afterburner..
  9. #9
    Sep 2011
    15
    51
    I'm not saying you should use the card as i said.
    just suggestion to try and see if that settings will fix the issue
  10. #10
    ROG Member Array
    Jun 2012
    14
    New Bios update..
    Hope it won't downclock it too much..
    http://www.asus.com/Graphics_Cards/N...2GD5/#download
Tags for this Thread
