I think you may have megabits and megabytes mixed up. Did you mean you use to get 80Megabytes and now you're only seeing 35-40megabytes?
Normally a harddrive will loose performance as it fills due to how the data is written to the spinning platter. The outside is written to first, and then the heads move to the inner portion of the platter which doesn't spin as fast as it fills up. Is the drive almost full? I have used both an external laptop HDD and a desktop HDD in a USB 3.0 enclosure, luckily I haven't experienced any speed problems yet. Is the drive its transferring to almost full or in use? Those could also potentially cause the transfer to slow down.
(ROG has simply become too expensive compared to the competition with same specs... 😞 )
MSI GE75 Raider 10SGS - i7 10750H - RTX 2080 Super - 32GB Ram - 1TB WD NVMe - 2TB 960 EVO - 300Hz 17inch Display
RETIRED: ALIENWARE R17 R5 - i7 8750H - GTX 1070 @ 1.9Ghz - 16GB DDR4 - NVMe 970 EVO 1TB - SSD 960 EVO 1TB
SOLD: ASUS G703VI-XH74K, RETIRED: ASUS G752VY-DH72, RETIRED: ASUS G750JH DB71 , RETIRED:ASUS G74Sx DH72
