Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    ROG Guru: Yellow Belt Array
    May 2012
    44
    233
    What are your stress-test max GPU & CPU temperatures and fan speeds?
    I've been running Prime95 and FurMark simultaneously for about 20 minutes with HWiNFO64 to do the monitoring and was wondering what other folks have been getting for their temperatures and fan speeds. Post up your build (if it's stock or if you got a thermal compound upgrade), your testing settings, and the max temps.
    So here's mine:
    G75VW-BBK5 stock thermal compounds; no overclocking of GPU
    FurMark setting: 1920x1080 windowed, Anti-aliasing 8X MSAA
    Max GPU temp: 70 degrees C
    Max GPU fan speed: 3455 RPM
    Prime95 stress test
    Max CPU temp on any core: 83 degrees C
    Max CPU fan speed: 3422 RPM
    G75VW-BBK5 (Stock configuration with added Crucial M4 256GB SATA SSD as OS boot drive)
    Need to know how to restore your G75 to it's factory-like condition? Go to my step-by-step guide:
    Step-by-Step: Using ASUS Recovery DVDs to Restore G75
    Want to download the latest drivers and utilities for your G75/G55? Go to this thread:
    Downloading New Drivers/Utilities for G75/G55
    ROG Guru: Green Belt Array
    May 2012
    46
    615
    My results on my G75VW BBK5 stock using Intel 520 SSD and 8 gb memory upgrade:
    Stock thermal compound no overclocking of anything ... same tests as Cecils ( for 20 minutes both running simultaneously ).
    Max CPU temp was 78 C ... Max GPU temp was 73 C and both fan speed max were around 3500 rpm.
    May 2012
    44
    233
    John: How long did you have the tests running for (just out of curosity).
    May 2012
    46
    615
    Quote Originally Posted by Cecil_2099 View Post
    Updated my post ... 20 minutes like your testing.
    ROG Member Array
    Jun 2012
    14
    Regarding Prime95, my G75 runs the 64-bit version of Windows 7 - so am I supposed to download version 27 of Prime95 from here: http://www.mersenne.org/freesoft/default.php and click on the link for the 64-bit version of Windows 7 under "Setup Instructions for New Users" - Step 2?
    Also, could you please post instructions for noobs (like me) to help us download, install, and run Furmark using the proper options & settings?
    Thanks in advance?
    May 2012
    44
    233
    Yes, download the 64-bit version of Prime95.
    For Furmark, go to: http://www.ozone3d.net/benchmarks/fur/
    Click the orange "Download Furmark" button.
    Scroll down and under "FurMark 1.10.1 Download" click the lime-colored download button with the big black arrow.
    Install it as any normal program.
    When you run it you can just click the "burn-in benchmark 1920x1080 15min button" or you can adjust the settings by changing resolutions, turning on anti-ailiasing, etc. and clicking the "Burn-In test" button. That one will go for as long as you leave it.
    I usually have HWiNFO64 running in the background to monitor the CPU & GPU temperatures and their fan speeds.
  7. #7
    ROG Member Array
    Jun 2012
    14
    G75VW-DS72 stock thermal compounds; no overclocking of GPU; no changes made to the hardware at all.
    FurMark setting: Burn-in Benchmark: 1920x1080 windowed, Anti-aliasing 8X MSAA
    Burn-in Score: 1522 points
    Max GPU temp: 74 degrees C (in Furmark); 61 degrees C (in HWInfo)
    Max GPU fan speed: 3642 RPM in HWInfo; I didn't see a value for this item in Furmark.
    Prime95 stress test [Torture Test options set to Blended (tests some of everything, lots of RAM tested)]
    Ran test for 30 minutes.
    Max CPU temp on any core: 84 degrees C
    Max CPU fan speed: 3654 RPM
    Question: Does the above data indicate that my G75 is functioning within normal parameters?
  8. #8
    May 2012
    129
    Anything below 85 C max for both GPU and CPU max on stress tests is within normal parameters. Ideal would be around 70 though.
  9. #9
    ROG Member Array
    Jun 2012
    14
    Quote Originally Posted by Liquidus View Post
    What do I need to do in order to achieve that ideal 70 degrees C?
  10. #10
    May 2012
    46
    615
    Quote Originally Posted by ValenB5 View Post
    Your max temp of 84C on CPU is a little higher than anything I ever received ... even pushing with prime95 my highest ( brief ) temp was 75 C but it then evened out a little lower.
    Wondering if you had something blocking air flow out the back of your unit ... both exhausts will push hot air out the back and if the air cannot go anywhere could get a little warmer.
    Normally most of us do not push the CPU workload very aggressively so under normal load temps much cooler than max temps.
