Just an update...
Thank you John for the link to the ISO for Win 7 home premium with SP1. I will try installing that this weekend.
I have had several freezes occur since I posted this message and one of the strange things is the touchpad. Ever since my last install of Windows 8 my touchpad has never worked. I couldn't even install the drivers posted on the Asus site as I would get a message that it could not find any supported hardware. I had to go to Synaptics site and download their latest driver. Although it would install the touchpad never worked. Beginning yesterday it started working. Today my system froze and it is back to not working. I am going to uninstall the drivers to see if it is possible the touchpad drivers could be causing my freeze problem.
Also, I posted a message in the thread regarding the subwoofer range thread
http://rog.asus.com/forum/showthread.php?17189-To-those-with-G75-subwoofers-producing-the-full-range...I have not been able to get the audio to work properly however again starting yesterday while typing my message I went into the HD audio deck one more time and I activated expert mode again. Went to the speaker setup and there are now options for 2.1 channels and loudness equalization. Both options work and the sound from the laptop is MUCH better. Although after rebooting I have to go back and set those options again. They do not get saved.
My function keys are not working still so I have no way to adjust audio or any of the other settings via function keys.
I will make this recommendation to those with audio issues. DO NOT use windows audio settings to change speaker configs. Only use the VIA HD Audio Deck. Windows config and HD Audio Deck do not communicate with each other very well and you will find yourself with a messed up situation is you do.
