Before i had two Asus GTX 680 SLI. My 3DMark score was P17326.
Now i have two DCII TOP's running in SLI and i cant seem to get the scores higher than P16560.
I've used Asus GPU tweak on both setups and i cant get the DCII TOP's higher that 1294Mhz in SLI (single 1304Mhz).
Any input on how this is possible? I mean, you would believe that the non overclocked DCII TOP's at 1202Mhz, would give a higher score than the overclocked reference 680's at 1137Mhz.
This is running with a 3770K @ 4,8Ghz and 16Gb 1866 corsair dominators.
