Results 1 to 7 of 7
    sager
    Guest
    Using UEFI (BIOS replacement)
    G73JW. I see that I have the UEFI option from the factory-installed BIOS on this notebook, running Win 7 x64. Couple of questions before I try enabling it:
    1. How will enabling it affect the original BIOS?
    2. Will I be able to disable UEFI and revert to original BIOS at any time?
    3. Are there any issues with UEFI and current disk partitions, etc?
    4. Currently I am not able to boot from USB, does enabling UEFI allow that?
    I've found lots of info about UEFI in general, and for a few other Asus models, but not specifically for G73JW series.
    Thanks.
    ROG Member Array
    Mar 2011
    5
    It appears you have to install Win 7 with UEFI enabled. I enabled UEFI and didn't notice anything on a current Win 7 Install. I would also like to know if anyone has done this.
    ASUS G73JW
    1920x1080 Glossy
    120G OCZ Vertex 2 + 500G 7200 RPM HDD
    i7-Q740
    16G Ram
    Intel Ultimate N 6300
    NVIDIA Geforce GTX-460M
    Blu-Ray Reader
    asusrog
    Guest
    need more info and user experiences before i turn on my uefi bios. I have a G73JH and have this option on 213 version
    ROG Member Array
    Mar 2011
    5
    I tried to boot a Win 7 Pro x64 DVD in EFI mode, but couldn't figure out how. It would be nice to have some instructions.
    ASUS G73JW
    1920x1080 Glossy
    i7-Q740
    16G Ram
    Blu-Ray Reader
    ROG Guru: Orange Belt Array jorlanm's Avatar
    Apr 2011
    313
    I for one also like to get info on this...Ive been reading about it...but I dont know how to start using it?
    -ASUS ROG G73SW-3DE-
    -Intel Core i7-2630QM Mobile Quad Processor
    -Intel HM65 Express Chipset +ICH10
    -17.3" 1920x1080 120Hz Anti-Glare Matte Screen
    -nVidia GeForce GTX 460m 1.5GB GDDR5 VRAM
    -nVidia 3D Vision Active Shutter Glasses
    -Creative EAX Advanced HD 5.0
    -THX TruStudio
    -8GB DDR3 1333MHz RAM (Max 32GB)
    -2x500 Seagate Momentous XT Hybrid HDD
    -Blu-Ray 4x Burner
    -Logitech Performance MX Darkfield Laser Mice
    -Microsoft Windows 7 Ultimate
    -XBOX360, PS3, Wii
    New ROGer Array
    Jul 2011
    2
    Red face Solved :-)
    Finally I did solve this...
    Download rufus, create usb with windows iso and select UEFI only (GPT)...
    Bios will find USB and installation will create right GPT table on disk ;-)
    Done
  7. #7
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    111
    4,186
    Here are a few links to help explain how it done. Your win 7 ISO has to have the boot 64 file created Install Win 7 UEFI
    http://rog.asus.com/forum/showthread...untry=&status=
    http://rog.asus.com/forum/showthread...untry=&status= this link was for G75 but applies as well to the G73 etc. The basic proceedures are the same for all notebooks drivers as specific your particular notebook.
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
Similar Threads
  1. replacement fan?
    By ndenovchek in forum ROG Gaming Notebooks
    Last Post: 03-16-2011, 12:06 AM
  2. NB Fan replacement
    By icecube in forum Other Series Motherboards
    Last Post: 01-27-2011, 04:22 AM
  3. Replacement parts for G73JH?
    By mertesn in forum ROG Gaming Notebooks
    Last Post: 12-07-2010, 09:08 AM
  4. User Serviceable replacement parts
    By Pyro411 in forum ROG Gaming Notebooks
    Last Post: 11-19-2010, 03:08 PM
