Results 1 to 3 of 3
    Magthere
    Guest
    4.0 Ghz i7 950 w/ Air cooler?
    Hello all,
    First time OCer with a simple question. As a note I don't yet have the system put together and I'm doing a little bit of pre-planning and research.
    Is it possible to safely reach 4.0 Ghz with an i7 950 running on a Extreme III Gene mobo with a Cooler Master V6GT air cooling?
    Thanks all in advance for your answers.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,888
    Yes, it's possible and it has been done but it's going to depend entirely on the luck of the draw. Intel "bins" processors lower than they can actually clock according to what people want to buy. Some CPU's have a much higher ceiling than others. You may end up with one that requires more voltage to reach that speed and the heat may be too much for your cooler. If you are stuck on hitting 4 then be prepared to change the cooler, CPU, or both.
    TL;DR: Don't count on it but you may get lucky.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    TeamROG Array V2-V3's Avatar
    Mar 2010
    11
    482
    Overclocking a CPU can be a bit of a gamble when it comes to the maximum possible speed, every CPU has a different overclocking potential. If CPU is capable of running 4GHz with lower Core voltage like 1.25V it may be possible to hold 4GHz stable on air cooling. To give it the best chance use an effective thermal paste and ensure proper contact between the heat sink and CPU, you do not want the cooler to be siting loosely on the CPU. Start with lower voltages to maintain the lowest possible CPU temperatures as your air cooler is the main limitation to holding a 4GHZ overclock.
Similar Threads
  1. Cooler Master V6GT CPU cooler with built-in LED strip
    By ottoyu34 in forum Overclocking & Tweaking
    Last Post: 03-30-2012, 01:58 PM
  2. Cooler Master ATCS 840 Case Mod
    By Victus in forum Case Modding & PC Builds
    Last Post: 08-17-2011, 06:18 PM
  3. Cooler for the G73JH?
    By thyes in forum ROG Gaming Notebooks
    Last Post: 03-17-2011, 02:37 AM
  4. Coolermaster SF19 Notebook cooler
    By Brian@ASUS in forum ROG Gaming Notebooks
    Last Post: 02-01-2011, 06:12 AM
  5. Need CPU cooler help
    By surfnet in forum Other Series Motherboards
    Last Post: 09-17-2010, 05:43 AM
