Results 1 to 5 of 5
Thread: Fan noise
    ROG Member Array Paco Strano's Avatar
    Jan 2011
    5
    Fan noise
    Hi all
    Got my Asus G73JH-A1 almost a year now and its being since 3 month that one of the fan make some noise now. I think is the CPU side, which is on the left side. The noise will start when start my laptop and after maybe 2 min the noise will stop.
    Do you think I should replace that fan or wait until the noise go really bad?
    Thanks for your reply.
    Paco
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    294
    7,410
    You can try using canned air to blast the dust. Some people have reported less noise after a good cleaning. If you still get noise then that means that the bearing is starting to go out and the fan will need to be replaced.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Jan 2011
    5
    Ok cool I will try that
    thx for your reply
    Tehori
    Guest
    Is it a very high-pitched noise? If so, I hear this is a known issue that effects the majority of Asus laptops, not just G73's.
    Jan 2011
    5
    Quote Originally Posted by Tehori View Post
    Yeah I will only do it when I start the laptop for 1 or 2 min and it will stop. Even when I'm gaming it will not do it. I will try the air can to make sure that there is no dust. If it does not do anything I will use my last free RMA. I still got 1 years waranty so
Similar Threads
  1. bsod and random freeze with loud noise
    By imdapro in forum G Series Gaming Notebooks
    Last Post: 03-01-2011, 04:22 PM
  2. Loud fan noise coming from right side of vent
    By billybobo325 in forum G Series Gaming Notebooks
    Last Post: 02-16-2011, 07:30 PM
  3. G51vx noise issue
    By gaurdianiii in forum G Series Gaming Notebooks
    Last Post: 01-02-2011, 11:06 AM
