08-08-2012 08:43 AM - last edited on 03-06-2024 07:07 PM by ROGBot
08-08-2012 08:56 AM
Hootch wrote:
Hello,
I hope to find a solution for my problem with the Asus Ai Suite Fan Xpert.
My problem is that Fan Xpert lose its profile/settings at boot up of the PC.
This results in that the PC sounds like an airplane, which is extremly frustrating.
I want the profile/setting to stick and load at every startup and not have to manually change it every time.
What to do?
FAN Xpert v1.01.06
AI Suite II v1.02.07
Win 7 64-bit
// H.
08-08-2012 09:12 AM
lenehan wrote:
Check your fan speed control over at the bios>Monitor Menu.>Fan speed control.
08-08-2012 09:22 AM
Hootch wrote:
I've done that and both CPU and Chassis are enabled with the right settings.
Problem still remains.
08-08-2012 09:50 AM
lenehan wrote:
Can you providre your setting.
08-08-2012 09:58 AM
Hootch wrote:
CPU Q-Fan Control Enabled
CPU Fan Profile Standard
Chassis Q-Fan Control Enabled
Chassis Fan Speed Low Limit 600 RPM
Chasis Fan Profile Manual
Chassis Upper Temperature 40
Chassis Fan Max. Duty Cycle (%) 60
Chassis Lower Temperature 40
Chassis Fan Min. Duty Cycle (%) 60
08-08-2012 11:42 AM
lenehan wrote:
Can you try to reset the setting to default. And let the AI do handle the setting.
08-21-2012 01:05 PM
08-21-2012 01:31 PM
09-05-2012 01:37 PM
