Hello guyz,
i bought an Asus G73SW 4 days ago, and i am surprised by the GPU fan noise.
i had an PackardBell LJ75 230 with a HD5650 who was completly inaudible, and i really hear the difference.
Even if i put my computer to saving battery mode, i can hear the GPU fan.
My temps are normal, CPU and GPU are between 30 and 40 degres when i am surfing or using MS Office.
When i am playing (Crysis 2), i can hear both fan, at max speed, which is normal, but on idle, the right fan is less noisy but i can still easily hear it.
Is that normal?
Maybe yes because the GPU is powerfull, but i would like to know if people has the same problem.
Should i ask for a refund and maybe buy the N73SV for example with Optimus technology?
Best regards.
