Results 1 to 3 of 3
Thread: HDMI problems
    Arxon
    Guest
    HDMI problems
    Ok, I have a g73jh the best buy version. I am working with two monitors right now. As soon as i plug in the HDMI it goes to a black screen on the laptop and become non-responsive. Updated video drives and all that and still nothing. 2 different hdmi cables both known to work. Anyone with any suggestions?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    309
    7,668
    Does unplugging the cable then restore functionality? Does anything flash or appear on the external display? It sounds like the laptop is trying to switch to external (rather than cloning or spanning to both displays) and something is not working correctly.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    BladeZero
    Guest
    Your monitor screen going black is most likely because the computer sets itself to run on one monitor. Is the monitor your running the HDMI cable to have video? Is it set to HDMI so you can see a picture on it?
    If it does then right click on the desktop, go to Screen Resolution, then go to Multiple Displays and you can select Duplicate Displays to get the video on both monitors, Show Desktop only on 1 for the computer monitor to get video only on that mintor, and show desktop only on 2 to get video only on the second monitor.
Similar Threads
  1. g53jw-a1 to tv hdmi
    By eldiablo in forum ROG Gaming Notebooks
    Last Post: 04-06-2011, 06:40 PM
  2. HDMI Gaming on TV
    By Dtrem5 in forum ROG Gaming Notebooks
    Last Post: 02-26-2011, 05:21 AM
  3. G53jw hdmi-cec ?
    By neodecker in forum ROG Gaming Notebooks
    Last Post: 02-24-2011, 07:40 PM
  4. HDMI out defeats SPDIF(?)
    By rarewolf in forum AMD Graphics Cards
    Last Post: 01-21-2011, 07:32 PM
  5. Struggling with audio over HDMI
    By byc in forum ROG Gaming Notebooks
    Last Post: 12-27-2010, 10:16 PM
