Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 43
    ROG Guru: Orange Belt Array MonsterMawd's Avatar
    Apr 2011
    70
    480
    Guide to Tools for PC & Case Modding
    These are the most common Tool I use for Case Modding.
    THINK SAFETY FIRST!
    Smith & Wesson Safety Glasses, $9.99,
    http://www.mnpctech.com/Safetyglasses.html
    CREWS "Stratos" Safety Glasses, $6.99
    Respirator Mask with canister filters
    Use when sanding, painting or using any hazardous chemicals
    Wear Latex or Rubber gloves for handling any type of chemicals and Paint products.
    Work Gloves for use with any equipment, including Power Tools
    Rotary Cutting Tool
    The most versatile tool for case modding. You can cut plastics, metals, grind and polish.
    Black & Decker RTX Rotary Tool
    Dremel brand is most popular.
    I hear a lot of complaints about cutting discs breaking when cutting metal. You need to use aluminum reinforced discs like these 1.5" Reinforced Dremel Cutting Discs
    http://www.mnpctech.com/Discs.html
    Cordless Power drill
    Minimum volts recommened 14.4V) with bit sizes 1/16 through ½ for cutting various mounting holes and operating hole saw attachments.
    Hole saw attachments for Drill
    For cutting fan holes in acrylic and metal.
    80mm = 3” hole saw
    92mm = 3.5” hole saw
    120mm = 4.5” hole saw
    140mm = 5.5" hole saw
    In order to use the Hole saw, you'll need an Arbor that fits your Powder Drill or Drill Press. Mine is 1/2"
    http://www.amazon.com/Lenox-Tools-300033L-Solid-Shank/dp/B0015B9RUM/ref=sr_1_6?ie=UTF8&s=hi&qid=1279126841&sr=1-6
    5.5" size bi-metal Hole Saw Attachment (140mm = 5.51181)
    Amazon has 5.5" "Bi-Metal" Hole Saw attachment for your Power drill, http://www.amazon.com/s/?ie=UTF8&keywords=5+1%2F2+hole+saw&tag=googhydr-20&index=aps&hvadid=3576615141&ref=pd_sl_8tlvzl1m8 e_b
    3/4" Hole saw attachment for 22mm Vandal Resistant Power Switch
    http://www.mnpctech.com/Vandal_Resistant_Switch.html
    80mm, 92mm, 120mm, 140mm Fan grill printable templates
    http://www.mnpctech.com/Fan_Grill_Templates.html
    120mm, 140mm, 240mm, 360mm, 420mm, 560mm Radiator & Grill (15mm & 24.5mm spacing) printable templates
    http://www.mnpctech.com/Radiator_Grill_Templates.html
    Greenlee Knock out Punches
    Greenlee part # 730EBB-120 Last time I inquired, they were around $450 in the states + Large 3/4" socket wrench, and 2" socket. I wouldn't use anything less than 19" long socket wrench. Estimated purchase price of $550 new.
    Threaded shaft of Knock-out punch
    Knock-out punch blade
    Ready to cut hole.
    You need leverage. Using 19" Socket wrench to draw in knock-out punch balde
    Clean Cut
    I've had this 12" Craftsman Bench top Drill Press for 4 years without any problems, other than the LED swivel light burned out. 5 speed (manual drive belt) with digital depth readout and Laser cross hairs. $219.00 at Sears
    http://www.craftsman.com/shc/s/p_10155_12602_00921914000P?vName=Tools+%26+Equipme nt&cName=Power+Tools&sName=Bench+Power+Tools&prdNo =15&blockNo=15&blockType=L15
    * Item# 00921914000
    * Mfr. Model# 21914
    Grizzly 14" Bandsaw, 3/4 HP for cutting plastic for window and metal sheets for scratch building
    http://www.grizzly.com/products/14-Bandsaw-3-4-HP/G0580
    Aluminum fence!
    Drill bits for cutting Plastics
    http://www.mcmaster.com/#drill-bits-for-plastics/=9hldrb
    Metal drill bits will not work for acrylic or plastic, they're made to bite into the metal as they are pushed into it. If they are used on acrylics they will chip and cause other damage to the plastic. When drilling holes for screws, you must make the hole larger than the screw itself to allow for expansion and contraction of the material. If not you will cause stress cracks at the hole and they will spread!
    Roper Whitney No. 5 Jr Hand Punch kit
    https://www22.ssldomain.com/roperwhitney/store_detail2.cfm?groupingid=68&categoryid=53
    (for cutting fan mounting holes or enlarging existing fan mounting holes for rubber silencing grommets)
    Hand Punch makes clean fan screw holes. No deburring.
    Jigsaw
    A Jigsaw should be in every Modder’s arsenal of tools. It’s the most efficient hand power tools for cutting a chassis or case panel. The $39.97 price tag on this Black & Decker JS660 is very good!
    Used for cutting panels and acrylic sheets. (minimum 18 teeth metal cutting blade) Black & Decker brand Jigsaws
    http://www.blackanddecker.com/ProductGuide/CategoryOverview.aspx?cPath=1496.2052
    A Jigsaw is great for cutting [url=http://www.mnpctech.com/acrylic_colored_sheets_casemod_windows1.html]Cast Acrylic sheets for PC case windows.
    Hand files
    Deburring jagged edges on both plastic and metal.
    Mouse Sander
    Sanding body filler. Prep case panels for paint.
    12” and 24" Combination Square Rulers
    Aligning windows, fan holes etc
    Scotch #4010, Super strength adhesion clear mounting tape. Used for mounting windows in computer cases.
    http://www.mnpctech.com/scotch_4010_tape_of_the_casemod_gods.html
    Pop Rivet Gun
    If you're going to dismantle you PC chassis, you will need a Pop Rivet gun and new pop-rivets. I use 1/4" length, 1/8" diameter, Gripe range .092" - .125" A Pop rivet gun is used to attach two pieces of any type of material together to make them one. It can attach anything from plastic, aluminum, and even metal. A rivet has two parts, the pin and the rivet. What the rivet gun does is push the pin through a pre-drilled hole, which is going to slightly larger then the rivet you have. Then you are going to put the rivet through the pre-drilled hole first. Then you squeeze the gun compressing the ring into the rivet, expanding the rivet out larger then the whole and the rest of the pin breaks of in to the gun. This makes it so the two pieces are now together for whatever you are going to use it for.
    Most Computer Chassis will accept 1/8” diameter Pop rivets, Gripe range .092" - .125" for Computers, http://www.mnpctech.com/Pop_rivets_for_computer_case.html
    Metal Nibbler
    Cutting case panels
    Metal Tin snips
    Used for Cutting Modders Mesh & Sheet metal
    Solder Gun or Pencil
    Heat Gun
    Heat shrink tubing, bending acrylics/plastics
    Craftsman 8" bench top sander. I've been using the disc sander primarily for acrylic and aluminum pieces.
    http://www.craftsman.com/shc/s/p_10155_12602_00922500000P?vName=Tools+%26+Equipme nt&cName=Power+Tools&keyword=belt+sander
    PSU and Molex Tools, for sleeving his Power Supplies, http://www.mnpctech.com/ATX_Molex_Removal_Tools.html
    PC Modding Rule
    http://www.mnpctech.com/PC_Modder_Ruler.html
    A measurement tool made exclusively for PC Building and Modding. Identify cooling fan sizes, computer screw threads, Vandal resistant switch, watercool barbs and hose diameters. Template locations for mounting internal and external drives. Thickness gauge for most common build materials.
    Templates.
    16mm / 22mm Bulgin, Lamptron switches, G-1/4 & G 3/8 watercool barb and hose. 2.5" SSD, 3.5", 5.25 optical drive screw locations.
    Fastener Gauge.
    6/32, 8/32, 10/24, 10/32, 1/4-20, 3MM, 4MM, 5MM, 6MM
    Thickness Gauge.
    Tap / Drill & Decimal Conversion Chart.
    Measures Inches & Millimeters
    CNC milled by Mnpctech from 1/8" thick solid aluminum and measures 12" x 2"
    I will be posting more Tool Suggestions and encourage you to share your own!
    MIA ROG Guru Array
    May 2010
    14
    1,039
    Very nice. So of those tools would have made all my modding easier if I new they made it. lol
    "I would rather be gaming!" Grunts-clan.com
    http://Pcjunkiemods.com
    http://c2cmods.com
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    301
    7,622
    I'm not sure if they were just out of stock at the time but I had a difficult time finding a 1" hole saw for a fillport installation. I finally ended up finding it in a door lock installation kit. So if anyone else has that problem, that's where you can find it for sure.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Apr 2011
    70
    480
    @pcjunkie, which ones? from looking at yr worklog photos, it looks like yr garage may be nicely equipped with tools (btw: I tossed in the PSU Tool samples with your order :-)
    @xeromist, I found that one at Home Depot, also try Lowes, or even Ebay
    MIA ROG Guru Array
    May 2010
    14
    1,039
    Well the hand punch and hole punch the high $$$ one. I have most of the other tools. But for holes I always use my scroll saw no hole saw. I might change up though. And thanks on the order.
    http://c2cmods.com
    Apr 2011
    70
    480
    Quote Originally Posted by pcjunkie209 View Post
    Right, and I hardly use mine anymore since more case manufacturers have made 120mm cooling fans almost standard
  7. #7
    MIA ROG Guru Array
    May 2010
    14
    1,039
    Quote Originally Posted by MonsterMawd View Post
    Ya but they must come in handy for scratch builds!?!
    http://c2cmods.com
  8. #8
    Apr 2011
    70
    480
    We just mill everything for scratch builds. The Knockout punch is great for adding holes to side panels or removing factory perforated grills
  9. #9
    ReU_VOoDOo
    Guest
    I wonder if these guys were union sheet metal workers before they started, because I have every one of those tools, LOL!
  10. #10
    MIA ROG Guru Array
    May 2010
    14
    1,039
    I have been doing all by hand. Can't wait to get m hands on some real machinery! Soon !!
    http://c2cmods.com
Similar Threads
  1. MORE AIR?! Guide to adding 250mm cooling to your case
    By MonsterMawd in forum Case Modding & PC Builds
    Last Post: 05-04-2011, 04:26 PM
  2. Modding resources
    By DarthBeavis in forum Case Modding & PC Builds
    Last Post: 03-16-2011, 07:06 AM
  3. ROG Experience Tour - Round 2 (Discussion thread for case modding)
    By pcjunkie209 in forum Case Modding & PC Builds
    Last Post: 09-07-2010, 06:55 AM
  4. Read before you OVERCLOCK or Case modding your machine!
    By Brian@ASUS in forum Case Modding & PC Builds
    Last Post: 04-30-2010, 12:59 AM
