Ok Its got real bad now! I had sometime yesterday to work on reinstalling the audio drivers and... Before i reinstalled the audio i decided to update the video driver for the 5870 to v11.4, rebooted the computer and it worked just fine, i then i uninstalled/reinstalled the audio drivers and rebooted again, after the reboot only the left speaker was working, i decided to go back on my restore point before i started all this. Everything seemed ok til it started to freeze on my desktop screen as it was still loading. I held the off butten til it turned off waited for 10sec then restarted it but now all i get is a blank screen like it never turned on at all, All the blue lights stay on even the little lights for the caps lock and Num lock. I called Asus they had me pull the battery hold the start butten for 1min and so on and they couldn't help. Is there anything more i can try?
