Cooler Master HAF 922 Case Mod
MonsterMawd
Level 12
This was my project for Stompfest, the canvas was the Cooler Master HAF 922 midtower
I'm using paper to make a template for 2x 120mm front intake plate.
Tracking template onto 1/8" thick aluminum sheet.
I used a Jigsaw with 18 TPI metal cutting blade to cut the design. I will refine and finish the cuts with a hand file later.
The 1/8" thick aluminum won't fit in my bending brake, so I used my bench vise to bend the aluminum.
I'm using a Mouse sander with medium Grit sandpaper to remove all of the blemishes and scratching in the surface of the aluminum
Aluminum plate surface is finished. Next step is fastening it on with pop rivets, more on this soon!
I've attached the new bezel plate on with pop rivets.
Overkill "Nautilus" 120mm fan grills, http://www.mnpctech.com/120mm_Overkill_Fan_Grills.htm
In order to use the Knock-out punch, you need to drill a 2" pilot hole.
Greenlee Knock out Punches
Greenlee part # 730EBB-120 Last time I inquired, they were around $450 in the states + Large 3/4" socket wrench, and 2" socket. I wouldn't use anything less than 19" long socket wrench. Estimated purchase price of $550 new.
12 REPLIES 12
xeromist
Yeah, the punch does look a lot easier than a jigsaw or hole saw. Someday when I have money to burn... 🙂
Holesaws will suffice in meantime!
The bezel temporarily attached
pcjunkie209
That looks sick! Great work. 🙂
"I would rather be gaming!" Grunts-clan.com
[SIGPIC][/SIGPIC]
http://Pcjunkiemods.com
http://c2cmods.com
Thank you junkie!
Better open up the rear exhaust for improved airflow as well before the chassis gets painted.
Rear exhaust grill on the HAF 922 chassis
Low tack masking tape (Scotch brand Painter's tape)
120mm Nautilus Fan grill
http://www.mnpctech.com/120mm_Overkill_Fan_Grills.html
Trace the inner opening of the 120mm Overkill Nautilus fan grill
Using Jigsaw with 18 TPI metal cutting blade.
I masked off the face of the Nautilus grill, then painted the inner walls of the openings with Black self etching primer. flipped it over, and painted the backside as well.
I then removed the masking tape and held the can roughly 16" away from the grill and sprayed the perimeter of it. This is how you achieve the speckled paint effect.
Rustoleum's Grey self etching primer. It reminded me of Military Grey.. I love the color.
I call it Alien camouflage ..heh
Here is the XIGMATEK XLF-F1254 120mm White LED Case Fans. These are rated 1500 RPM @ 61 CFM. Noise level is 20 dbA
Here is the custom HAF 922 front bezel and fan grills after receiving 4th coat of Charcoal Grey Metallic paint. The finish on the bezel will buffed out.
I'm installing the machined Diamond Knurl computer case feet on the HAF 922's PSU location is on the bottom, so you've only get 3/16" space for the fastener nut. I trimmed down 2 of the included 8/32 machine screws, to use these feet in the 922.
http://www.mnpctech.com/Aluminum_Computer_Case_Feet.html
I used 7/64 size drill bit for 8/32 size machined screws included with case feet.
Dusted the tops of the feet from 20" away with Black Self-etching primer... The bottoms are pure Black
Painted the 140mm fan grill.. should have done same effect, looking at it now.. oh welly!
I've also installed Acoustical foam in the HAF 922 chassis yesterday, starting on the backboard. It has Adhesive backing for easy installation. It cuts very easily with a scissors or Xacto knife. This foam will help dampen noise generated from inside the 922.
http://www.mnpctech.com/Acoustical_Foam_Sheets_PC.html
Painting the side panels...
MonsterMawd
Level 12
"LAN Terminator" dude surrounded by circuits hardwired into the system inside.
U-channel window molding, http://www.mnpctech.com/UChannel.html
I use the Clear 3M 4010 Heavy Duty Tape, http://www.mnpctech.com/scotch_4010_tape_of_the_casemod_gods.html
The case is done...
xeromist
I'm not really feeling the caution tape but the rest of the paint is sweet looking 🙂
