Results 1 to 4 of 4
    ROG Member Array
    Dec 2011
    LOW FPS on BF multiplayer or Crysis 2
    Hey can u help and send me how many FPS do u have while playing these games because when i´m playing on middle settings on HD i have about 17 - 35. It falls down every few seconds on 17 - 25 fps and its unplayable. Try to image you playing at 35 FPS make some move, turn around or some action happend and it falls down on 17-25 and jump on 30-35. That´s repeat every 20 maybe 10 seconds. When i change screen resolution lower its doing same on 1600x900 or 800x600. If i have middle or high settins doesnt matter nothing changed, only its falls down from 80 fps to 17 - 25 . I complaint NB twice, they changed motherboard with graphic card and adapter. Something is wrong with this computer. Please dont write about graphics drivers.. of course i have everything up date. Im confused i paid over 1600 euro and can´t play because its lagging! So please write me how many FPS do u have on HD with middle settings, 1600x900 and 800x600. Thank you
    Asus G74Sx - 3D - 17.3-inch Full HD display (1920 x 1080) - Intel Core i7-2670QM quad-core processor (2.2 GHz with Turbo Boost 2.0 up to 3.1GHz) - NVIDIA GeForce GTX 560M 3GB GDDR5 VRAM - 16GB DDR3 SDRAM, 4 x SODIMM Sockets - 750GB 7200RPM hard drive #1 & 750GB 7200RPM hard drive #2 - WIN 7 ULT 64BIT.
    New ROGer Array
    Sep 2012
    4
    Quote Originally Posted by x0rkinko View Post
    Check this out right here.
    ROG Member Array
    Dec 2011
    Thank you .. i hope it solve my problem... i will give u a response ..
    ROG Member Array
    Dec 2011
    It´s working ... Thanks...
