g74sx hard drive
startrekmaniac
One of my hard drive died, I got an error message saying that my drive was invaild than my d and e drive deleted themselves from my computer. I need to replace it, my question is which hard drive should I replace it with, I was wanting to get a drive with hard disc space.
7 REPLIES 7
dstrakele
Level 14
This one will do the trick: http://www.amazon.com/gp/aw/d/B004I9J5OG.
G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
Thanks for the reply, could I find this at best buy? Is there are hard drive that is at least 1tb?
dstrakele
Level 14
Best Buy does sell that drive. The 1 TB drive is slower - 5400 rpm.
Forget slow 1TB spinning disks: get http://gizmodo.com/5851546/the-worlds-first-25+inch-1tb-solid-state-drive-needs-to-get-in-my-laptops...
Sell your first-born. Ya know ya want it.......
G74SX-CST1-CBIL, i7 2630QM 2GHz
32GB DDR3 RAM @1333MHz
GTX560M 3GB DDR5 (192 bit)
17.3" LED 1920x1080
Sentelic TP, BIOS 203
Debian Linux Wheezy (Testing) Kernel 3.2, NVIDIA 295.40
Can some one tell me which drive, carried the d and e partions? Is it the first or second drive?
Its the one without the sticker (on the plate). on the right (when its upside down) ... made that mistake when I installed a SSD.
$1,100 for a TB... Baldercrap... when they finally come out they will probably retail for (cue pinkie finger) ONE MILLION DOLLARS
