Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 66
  1. #21
    ROG Enthusiast Array Kinesis22's Avatar
    Sep 2012
    34
    How does this one look? Have you had any experience with the Antec TP series?
    http://www.antec.com/product.php?id=1760&fid=236
    It says it has an 8pin etx and a 4pin atx on the website there.
    ~Kinesis22
    "Since there's only one of me shouldn't my opinion be doubled?"
    "Is it possible to play that game in your sleep?" "Oh definitely, I think better in my sleep."
  2. #22
    Dec 2011
    354
    25,742
    Yes I have used them many many times in builds I do for extreme gamers. That is one solid PSU.
  3. #23
    Sep 2012
    34
    Ok, what happens when a power supply dies? Does it mess up all the other components? Or does it just stop working?
    ~Kinesis22
  4. #24
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    183
    8,306
    It does depend how it dies... in certain circumstances it could damage other components too... - but today's mobo's are pretty good in their own protection mechanisms too
  5. #25
    Dec 2011
    354
    25,742
    I have seen, VGA's die, CPU's die (this is the most common causality) and quite surprisingly HDD die often too. Then you have the motherboard itself that can pop CAPs or melt other bits. It can be ugly.
    The single most underrated piece of hardware is your PSU. And you know what? It is the foundation for all your systems strengths or weaknesses.
  6. #26
    Sep 2012
    34
    Ok thanks for all the help, just making sure, this one looks good?
    Antec TruePower New TP-750 750W
    ~Kinesis22
  7. #27
    Space Janitor Array fronzel's Avatar
    May 2012
    16
    73
    On a sidenote, looking at your setup in the first post, I would really recommend using an SSD.
    ASUS Maximus V Formula | Intel 3770K | Corsair Vengance 4x4GB 1600
    ASUS GTX 680 DC2 TOP | Seasonic X-760 Gold | Lian Li PC70
    Samsung 830 256GB | WD Green 3TB | Dell U2711 | Win7 64
  8. #28
    Dec 2011
    354
    25,742
    Quote Originally Posted by fronzel View Post
    You know I did not even pick that up - no SSD in the system. And with the price of SSD's so good right now and the simple huge difference an SSD for OS and applications makes to a system is difficult to comprehend until you go from a mechanical drive to a SSD so big thanks fronzel for that suggestion.
  9. #29
    Sep 2012
    34
    I was just about to ask what brands of ssds are good. Is SanDisk good? Because I just found this:
    SanDisk Extreme SSD 120 GB SATA 6.0 Gb-s2.5-Inch Solid State Drive SDSSDX-120G-G25
    What is an ok storage amount? Is 120GB ok for running Windows 7, some games and whatever programs have to be on it?
    ~Kinesis22
  10. #30
    Dec 2011
    354
    25,742
    They are all pretty much the same. All those on a good price have the Sandforce controllers which are super quick. 128GB is good to go for an OS and applications. Just manage your download folder and also your libraries, my documents and all those. So if you have like I do a pretty large music collection do not store them on your SSD. Same for moves I guess. What I did was shift my iTunes folder some place else.
Tags for this Thread
