Results 1 to 7 of 7
    oogawooga
    Guest
    g73jh speaker crack problem
    okay..... I've had this problem for a long time already i just never decided to fix it properly and have been using earphones to fix the problem....
    http://www.youtube.com/watch?v=mKTYSJr4PTEYouTube - Asus G73 Random Noise Problem thats a video with the same exact problem i have. i just leave my laptop there with no video or games running or anything that produces sound and it just cracks like crazy
    sucks because i wouldnt be able to bring this to class unless i have a headphone
    im on windows 7 ultimate 64-bit and using bios 211
    TeamROG Notebook Member Array Chastity@ASUS's Avatar
    Oct 2010
    18
    1,334
    It's been suggested that the issue arises from the audio chip getting too warm from system heat. Personally, I would open up the case, and reseat the fans, plus blow out the vents for any accumulated dust bunnies.
    Kicking Ass Since Today
    btotech.com
    Guest
    i can tell you i personally spent an entire work day messing with this. my help did as well. more then a few customers have too. i may not be up on the recent news regarding this issue as it is no longer relevant but never did find the solution on other then replace the audio board.
    btotech.com
    Guest
    this can happen on brand new units as well as returns / refurbs. the issue was rectified after the summer in 2010 for future production
    oogawooga
    Guest
    should i do some sort of mod to my laptop to prevent the audio from cracking? maybe a better fan? liquid cooling? idk....
    I left ASUS, please contact cl-scott Array
    Oct 2010
    15
    155
    I would recommend to send the laptop in for an RMA. I don't know of any fix other than replacing what's most likely causing the issue which is the audio board.
  7. #7
    oogawooga
    Guest
    i got this laptop off craigslist and its been about 8 months i think... so RMA is not an option
Similar Threads
  1. G73JH Wi-Fi Problem
    By killerwhale in forum ROG Gaming Notebooks
    Last Post: 02-18-2011, 12:09 PM
  2. G73JW-A1 Speaker Pop
    By alkaline in forum ROG Gaming Notebooks
    Last Post: 01-23-2011, 07:44 AM
  3. G73JH Problem
    By Michael in forum ROG Gaming Notebooks
    Last Post: 01-11-2011, 09:03 PM
  4. LCD Screen - Internal crack?
    By Benny in forum ROG Gaming Notebooks
    Last Post: 12-30-2010, 01:46 AM
  5. Sound and Speaker
    By martin_metal_88 in forum General Discussion
    Last Post: 07-28-2010, 08:19 PM
