I will be purchasing a Crosshair V Formula-Z Motherboard along with an FX-8150 (maybe, depending on your advice!)
I would really like to have the AMD FX-8350, however not sure when this CPU will be out, I have heard Oct. 17th but not sure if that is right or not.
I really can't wait, but I will if it’s a better buy! Would it be best to wait and purchase Crosshair V Formula-Z Motherboard and the AMD FX-8350 CPU, or should I forget about the FX-8350 and go ahead and just buy the FX-8150 CPU now?
Please let me know if it’s worth the wait or if I should buy now. (This all depends on the wait also, if its later then Oct, 17th I’ll probably buy now)
As for the Memory Type and Configuration I am stuck on the following:
G.SKILL Ripjaws Z Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model F3-2133C9Q-32GZH
Timing 9-11-11-31
Voltage 1.6V
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231564 G.SKILL Ripjaws X Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9Q-32GXM
Timing 9-9-9
Voltage 1.5V
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231569G.SKILL Ripjaws X Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C9Q-32GXM
Timing 9-10-9-28
Voltage 1.5V
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231616G.SKILL Ripjaws Z Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8Q-16GBZH
Timing 8-8-8-24
Voltage 1.5V
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231516Yes, I know I would ever use 32GB of RAM but, I will be using VMware WorkStation sometimes to learn a new OS to become certified!
What I’m really looking for is Stable Memory with great timings and speed that will go great with Gaming/Day to Day Applications, VMware, sometimes video editing, and web designing.
Also a couple of concerns I have read about is, the AMD FX-8150/8350 doesn’t support anything higher then DDR3-1866 (is this true, will the 2133 RAM be downgraded to 1866/1800?)
Another concern I had was the Asus Crosshair V Formula-Z Motherboard didn’t support DDR3-1866 and it’s not listed on the specifications page on Newegg or Asus Website, however it’s listed on the Memory Compatibility Chart from Asus for this MB! So does it support 1866 or not?
Please let me know what your thoughts and concerns are about different Memory Types and Configuration I have chosen and if you could please help me decide on what CPU to go with!
