Results 1 to 5 of 5
    ROG Guru: White Belt Array mjssge's Avatar
    Jul 2012
    11
    85
    HD7970 DC2 Top - OC setting advice
    Ive been thinking about getting some more juice out of this, but wanted to ask if anyone has some
    incremental set of figures I can try to OC it.
    Im currently using these:
    GPU clock - 1050Mhz
    GPU Voltage (mV) - 1174
    Memory Clock - 5600Mhz
    Many Thanks
    MJS
    Starport PAX Champion 2010/2012
    Main Gaming Rig:
    Asus Z77 Maximus V Gene, i5 3570k, Asus HD 7970 CU II Top
    Corsair 500r, be quiet 630w L8psu, 8gb Vengeance RAM, H100 water cooling.
    Corsair M90 Mouse.
    TV Gaming Rig:
    AMD-A10-5800k Trinity, Bit-Fenix Prodigy "Magma".
    Jul 2012
    11
    85
    470 views, some ROG'er must have a few settings for me?
    The OC is mainly for playing Arma 2 with 10k draw distance and high settings.
    Ive had a look at some settings elsewhere, but I trust this place first.
    Main Gaming Rig:
    Corsair M90 Mouse.
    TV Gaming Rig:
    ROG Guru: Green Belt Array lenehan's Avatar
    Jul 2012
    23
    544
    No standard setting. One man meat is another man poison. Unless your TOP card connected via Hotwire with ROG board which supported it. It better to stay as if. Unless Asus willing to release bios to change for better oc . It will be better to stay as it. Cheers.
    Change is the law of life. And those who look only to the past or present are certain to miss the future.
    Dec 2011
    354
    25,742
    I am able to run 1300MHz stable on two of my cards.
    On two others they both fail at 1150MHz regardless of the voltages.
    So as my friend Le has said it is up to the individual card and user to find what is the sweet spot. No two cards are the same.
    Jul 2012
    11
    85
    Thanks you 2, Ill run some benchmarks on arma2 oa.....and keep below 1300Mhz.
    Main Gaming Rig:
    Corsair M90 Mouse.
    TV Gaming Rig:
