Results 1 to 5 of 5
    New ROGer Array
    Sep 2012
    3
    What mini pcie wifi card for my Max V Gene
    Just bought a Maximus V Gene desktop mobo and I need a wireless card.
    I'd like to use the mini pcie slot.
    Ideally, the wifi card would also have bluetooth on board.
    I need the antenna(s) too.
    Any suggestions on which one to buy and where?
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,112
    was there no mini pcie card in the boks?
    New ROGer Array
    Sep 2012
    3
    Quote Originally Posted by Vortimid View Post
    Not on this model, just the msata / mpcie bracket.
    ROG Enthusiast Array
    Aug 2012
    19
    29
    I got a used AR5BHB92 off of eBay, but that's because I built a hackintosh and wanted the most compatible components possible. That one doesn't have bluetooth, and there may be better chips for Windows anyway.
    But for antenna, I can very much recommend the eBay seller "wifiexpert" (http://www.ebay.com/sch/wifi_expert/m.html) as he sells dual-band antenna pairs of various dBi with your length choice of included antenna - quite convenient.
    New ROGer Array
    Sep 2012
    3
    Good Rec
    Quote Originally Posted by Gabedamien View Post
    Thanks for the rec. Antennas and pigtails I will get there.
    Now, I need a good mpcie wifi recommendation.
Tags for this Thread
