Results 1 to 5 of 5
    New ROGer Array
    Sep 2012
    1
    Lil help plz, after changing my hdd (asus g55)
    Hello all
    So I change me 1T 5400RPM HDD to 120g ssd (sundick extreme)
    Now what do I do with the windows and all the asus software ??
    I did burn 5 AI recovery but how do I boot it
    Or is there something else I need to do
    So what is it ?
    ROG Enthusiast Array
    Sep 2012
    15
    45
    just normaly go to bios set boot priority from cd (normaly it's already in default), then just insert the first cd/dvd from backup u created and it will start the process, just follow the guide after it.
    ROG Guru: Black Belt Array rewben PC Specs
    rewben PC Specs
    Laptop (Model)G55VW-3D
    MotherboardASROCK Z97 EXTREME 6
    ProcessorINTEL 4790K
    Memory (part number)G.SKILL RIPJAWZ 2400MHZ (F3-19200CL10Q-32GBZHD)
    Graphics Card #1ASUS STRIX-GTX980-DC2OC-4GD5
    Graphics Card #2ASUS STRIX-GTX980-DC2OC-4GD5
    MonitorDELL U2713HM
    Storage #1SAMSUNG SM843 480GB X2
    Storage #2WD GREEN 3TB X2
    CPU CoolerSWIFTECH H240-X
    CaseNZXT H440
    Power SupplyTHERMALTAKE TOUGHPOWER XT PLATINUM 1275W
    Keyboard CORSAIR K70 RGB
    Mouse STEELSERIES KINZU V3
    Headset STEELSERIES 9H
    Mouse Pad STEELSERIES QCK+
    Headset/Speakers LOGITECH Z506
    OS WINDOWS 10 PRO AU
    Network RouterASUS RT-AC66U
    Jun 2012
    178
    2,229
    you can choose to:
    1. run the recovery dvds on the ssd. it's best you do this without the 1tb stock drive plugged in. you can refer here for the recovery process.
    2. install a fresh windows. you can grab the official drivers from asus website, or, follow the g75vw clean install guide here
    if possible, leave the 1tb stock drive alone, until you're sure everything is fine.
    note that the new firmware about TRIM fix for sandisk extreme hasn't come out yet. it's better to patch it first imo.
    New ROGer Array Zygomorphic's Avatar
    Mar 2012
    176
    4,761
    My vote is on #2, it gets rid of all the bloatware, which is really nice. Get the drivers from ASUS website and from vendor websites (nVidia at least).
    I am disturbed because I cannot break my system...found out there were others trying to cope! We have a support group on here, if your system will not break, please join!
    http://rog.asus.com/forum/group.php?groupid=16
    We now have 178 people whose systems will not break! Yippee!
    LINUX Users, we have a group!
    http://rog.asus.com/forum/group.php?groupid=23
    rewben PC Specs
    MonitorDELL U2713HM
    CaseNZXT H440
    Jun 2012
    178
    2,229
    Quote Originally Posted by Zygomorphic View Post
    me too then use windows backup and restore for recovery. simple and neat.
