So, Hard Drive Capacity...
keltbear
Looking on the Asus Website, it says up to 1tb, i know we have 2 bays, 1tb each?
is there a BIOS update that allows for larger hdd size? or is it possible to partition the larger HDD?
i was thinking a 256gb SSD and a 2tb standard secondary drive.
Thanks
10 REPLIES 10
zsld0423
Generally, these laptops will come with (for the 1tb) 2 500GB hard drives, but depending on where you get it from and what merchant, you can customize the storage to best suit your needs. If you're wanting to put in a SSD and have a 2tb secondary drive, your best bet would be to try and get it with 1 500gb hard drive, since that will probably be the cheapest. And of course you'd have to buy the SSD, and then for the 2tb drive you'd have to buy that separately as well. Windows will recognize up to 2TB I think as a single drive formatted as NTFS. For myself, I purchased a G74 with a 750GB hard drive, and then purchased my 64GB SSD off of newegg and it's running perfectly fine
Sager NP9370
256GB Samsung 840 Pro SSD + 750GB 7200RPM Secondary HDD
nVidia GeForce GTX 680M 4GB VRAM
Intel Core i7-3630QM 2.40GHz
16GB RAM
Mouse: MadCatz R.A.T. 7
Keyboard: Razer Lycosa Mirror
Additional Monitors: 24" 1080p Insignia LED/LCD TV and 21" Acer LCD Monitor
Windows 7 Ultimate
i already have the system, just looking to upgrade,
i was worried about the bios not recognizing the larger drive.
zsld0423
It should recognize it, I have a 3TB drive I put in my Desktop and it wouldn't recognize all of it until I formatted it a different way. But by default Windows 7 will see up to 2TB, so it shouldn't be an issue
Sager NP9370
16GB RAM
Windows 7 Ultimate
The recognition issues occur when you pass th 2 TB (BIOS) mark. UEFI is required to support larger HDDs than that. Two 1 TB HDD are accessed independently, so they will not be an issue...if you have the space. Make sure to get the 9.5 mm variants!
I am disturbed because I cannot break my system...found out there were others trying to cope! We have a support group on here, if your system will not break, please join!
http://rog.asus.com/forum/group.php?groupid=16
We now have 178 people whose systems will not break! Yippee! 🙂
LINUX Users, we have a group!
http://rog.asus.com/forum/group.php?groupid=23
This is a good thread...I have wondered about whether the G74 would work with 2x1TB HDDs or not...in fact, as soon as any 1TB 7200rpm HDDs in the small form factor hit the market I intend to find out andreplace my 2x500GB 7200 drives in there. Don't really want the slower 5400's either...
G74SX-CST1-CBIL, i7 2630QM 2GHz
32GB DDR3 RAM @1333MHz
GTX560M 3GB DDR5 (192 bit)
17.3" LED 1920x1080
Sentelic TP, BIOS 203
Debian Linux Wheezy (Testing) Kernel 3.2, NVIDIA 295.40
Should be fine, I doubt they will come out for a while though, considering that HDD sizes have almost stagnated. I guess the next jump will be when HAMR (heat-assisted magnetic recording) becomes the norm.
you said 2tb mark, so a 256GB ssd and a 2TB hdd wouldnt work?
Edit i guess they dont make a 9.5mm tall 2TB hdd, its a 15mm, so physical size is the limitation.
2TB if it fits will work. The G75 has the ability to do EFI booting, so you could go to some astronomically large capacity and it would boot. If you switch to EFI mode, you will have to reinstall Windows, but I would assume you are going to anyway.
zsld0423
Sorry, I meant 2TB per single drive. So having the 256gb ssd and the 2tb drive would work without any special preparation
Sager NP9370
16GB RAM
Windows 7 Ultimate
