Lag + Screen Flash on battery
Aliasmk
Hi Everyone! So I just got my G75VW last month, so far loving it, but for one thing. It seems that when I have the computer on battery power, every 10 seconds or so Im playing a game, my screen will flash black and the frame rate would drop to around 20 fps. Then, 10 seconds later, another black flash and the frame rate goes to normal. This will repeat, whether In in the game or at my desktop as long as the game is running.
I have the NVidia 670M, if it helps. Also, there was one time that I was on battery and it ran the game fine the entire time, and I played it for about an hour, no problems. But when i plugged it in and unplugged, the problem re appeared.
Any help would be greatly appreciated! 😄
shadowarrowny
Depending on the game you are playing, that is normal for the G75 from what I have read in the forum. I can tell you for sure that Skyrim is pretty much unplayable on mine with the power brick disconnected, but runs like a champ on AC power.
-Kevin
