Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 21
  1. #11
    ROG Guru: Yellow Belt Array
    Jul 2012
    221
    Sounds like a great build, post some pictures once you are done!
  2. #12
    ROG Member Array MR.COHIBA's Avatar
    Sep 2012
    12
    Will do mate! for now here some of the case and 2 components which found time to assemble! the mobo and the cpu are still packed since I ran out of money and I m missing some components! when I get them I'll finish it and post the final pics! Click image for larger version.
ID:	12237Click image for larger version.
ID:	12238Click image for larger version.
ID:	12240Click image for larger version.
ID:	12241Click image for larger version.
    -THERMALTAKE LEVEL 10 GT [RED THEME-ROG] - ASUS MAXIMUS V EXTREME - INTEL I7 3770K -
  3. #13
    ROG Court Jester Array Nackers's Avatar
    Jul 2012
    282
    871
    Cool Case, Is that ciggy lighter,
  4. #14
    ROG Enthusiast Array Razorbak86's Avatar
    Sep 2012
    58
    Quote Originally Posted by MR.COHIBA View Post
    PSU: OCZ FATAL1TY 1000W
    Have you purchased the PSU yet? If you haven't, I would recommend that you consider the Seasonic Platinum 1000W instead of the OCZ Fatal1ty 1000W. The Seasonic is a better PSU, and it is practically the same price. Compare the reviews for both units, and you'll see what I mean.
    JohnnyGuru.com
    Seasonic (9.7/10) : http://www.jonnyguru.com/modules.php...Story&reid=264
    Fatal1ty (8.4/10) : http://www.jonnyguru.com/modules.php...Story&reid=278
    TechPowerUp.com
    Seasonic (9.5/10) : http://www.techpowerup.com/reviews/Seasonic/P1000/
    Fatal1ty (8.8/10) : http://www.techpowerup.com/reviews/OCZ/FTY1000W/
    I know you're pursuing a red theme throughout your build, but if you go with the OCZ, you're just putting money into Johnathan Wendel's pockets for the Fatal1ty brand. ;-P
  5. #15
    Sep 2012
    12
    Quote Originally Posted by Nackers View Post
    yes it is! with a cup holder! You cant imagine how hard I tried to find it and get here in Cyprus!
  6. #16
    Sep 2012
    12
    Quote Originally Posted by Razorbak86 View Post
    JohnnyGuru.com
    TechPowerUp.com
    First of all thanks for the advise! The PSU will be bought last from where I live due to plug and electricity compatibility.
    Would you believe me if I told you that I dont know who that guy is?! and indeed it's a con that the PSU has some guys face on it!
    I saw the Seasonic and I also liked the CM silent pro hybrid 1050W one.. Its really a tough choise!
    Btw what are those 12-pin plugs on the seasonic?Click image for larger version.
  7. #17
    Sep 2012
    12
    Also with the Seasonic I ll have to buy sleeved cables which on average will cost me $10/each with the shipping and all.
  8. #18
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    199
    8,358
    Those connectors you highlighted are the PCIe power ones... for graphics card(s) - perhaps the other end of those cables is only 6+2 connector
  9. #19
    Sep 2012
    58
    Do a quick Google search on "Fatal!ty", and you'll learn everything you need to know about Johnathan Wendell.
    Those 12-pin plugs are "PCI-E" headers. The Seasonic 1000W Platinum SKU comes with six PCIe cables arranged in pairs on three PSU trunk connectors. (The 860W Platinum SKU only comes with four PCIe cables arranged in pairs on two PSU trunk connectors.) Each cable has one main PSU trunk connector and a pair of PCIe connectors (each 6+2 pins, so 2 x 6+2 pin cables per main trunk) used for connecting to graphics cards or other PCIe power connectors. Zoom in on the three vertically-oriented cables on the lower left of the following photo for a good visual.
    http://www.techpowerup.com/reviews/S...box_bundle.jpg
    One of the PCIe trunk connectors can also fit in the "PCI-E/CPU" combo connector in the upper right of the following photo, but that is an alternative plug-in option offered simply for purposes of convenience and/or cable management.
    http://www.techpowerup.com/reviews/S...anel_clear.jpg
  10. #20
    Sep 2012
    12
    not bad option from seasonic.. I'll visit the hardware shop in my city where I always get my stuff and check out what they have in stock. not everything on the internet is available here.
Tags for this Thread
