Results 1 to 8 of 8
    ROG Guru: Orange Belt Array MonsterMawd's Avatar
    Apr 2011
    70
    480
    How To Guide: Installing GPU Cooling Fan in side panel
    One of our customer sent us their Cooler Master Cosmos case to install a 120mm cooling fan and grill in their access side panel. Here are the steps we took in performing this case mod with a Greenlee Knockout Punch, but you can use this guide with 4.5" Hole Saw attachment on your Power drill or Drill press.
    List of Tools We
    Power drill or Drill Press
    Greenlee Knockout Punch with 120mm cutting blade, but you can use your own 4.5" Hole saw Attachment
    Measuring Square or Ruler
    Pencil or Pen
    Painter's Masking Tape
    Center hand punch
    X-acto Knife
    3/16" drill bit for fan screw mounting holes.
    Mouse Sander for removing adhesive residue from the sound insulation foam.
    Phillips Screwdriver
    "SEM brand Self Etching" Primer
    Plastikote's Silver "Engine Enamel" automotive aerosol paint.
    4x 8/32 Thread x 5/8" Length Socket Machine Screws
    1x 120mm Wire Fan Guard
    1x Black 120mm Round Hole fan grill
    4x #10 x 5/8 self tapping fan screws
    Our customer marked off the 120mm GPU Cooling fan hole location for us, with low tack masking tape.
    Using a 12" measuring Square and 120mm Wire Fan Guard to mark the fan hole location.
    Using hand center punch to mark the center of the grill location. This is for the 1" diameter Hole Saw attachment pilot drill bit.
    At this point, you can use a 4.5" Hole Saw Attachment on a Power Drill or Drill Press to make the 120mm fan hole.
    The 1" opening allows us to insert the shaft of the Greenlee Knockout Punch blade.
    Using X-acto Knife to cut square shape in sound insulation foam on backside of the panel.
    I used a Black & Decker Mouse Sander to remove the adhesive residue left by the insulation foam.
    To save time, we use a Greenlee Knock out Punch at Mnpctech.com. Greenlee part # 730EBB-120. Last time I inquired, they were around $450 in the states + Large 3/4" socket wrench, and 2" socket. I wouldn't use anything less than 19" long socket wrench. Estimated purchase price of $550 new.
    Crank and tighten the socket wrench to cut through the panel.
    Using 3/16" drill bit to make fan screw mounting holes.
    The advantage of using a Greenlee knockout punch is that the cut is clean! No need to clean up jagged edges.
    I painted this Black http://www.mnpctech.com/120mm_Custom_FanGrill.html
    120mm Round Hole fan grill with Plastikote's Silver "Engine Enamel" automotive aerosol paint.
    The 120mm cooling fan and grill installation looks clean and professional!
    Apr 2011
    70
    480
    This Cosmos grained aluminum panel look so nice. It served as a great canvas to compare how our machined aluminum 120mm grills look.
    Heres how the panel looks with 120mm "Turbo" machined aluminum fan grill
    Six Foot Ginger
    Guest
    I like it, I am just not brave enough to do it and I don't have the tools
    Apr 2011
    70
    480
    Maybe a friend or relative can help you Ginger?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    344
    8,054
    I'm sure that PCJunkie or I could pop a hole in a panel for him in no time if that's all that's needed.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    MIA ROG Guru Array
    May 2010
    14
    1,039
    Haha for sure!!
    "I would rather be gaming!" Grunts-clan.com
    http://Pcjunkiemods.com
    http://c2cmods.com
  7. #7
    Apr 2011
    70
    480
    no doubt! hehe
  8. #8
    ROG Member Array WolfSoul's Avatar
    Aug 2011
    16
    Ive been wondering bout getting this with my Storm Sniper
Similar Threads
  1. Replies: 3
    Last Post: 11-17-2013, 03:05 AM
  2. Installing second HDD
    By chadwick17 in forum ROG Gaming Notebooks
    Last Post: 12-23-2011, 06:55 PM
  3. Replies: 13
    Last Post: 10-27-2011, 05:02 PM
  4. MORE AIR?! Guide to adding 250mm cooling to your case
    By MonsterMawd in forum Case Modding & PC Builds
    Last Post: 05-04-2011, 04:26 PM
  5. P67 Deluxe USB3 Front Panel Box
    By Diogenes in forum Other Series Motherboards
    Last Post: 01-28-2011, 12:38 AM
