Results 1 to 9 of 9
    ROG Enthusiast Array
    May 2012
    20
    41
    Project Log: Thermaltake Kandalf LCS - Redux
    Had this case since '06, and have really liked its size, space and features. I am not a heavy modder if you will, but the case is lacking in appeal and functionality now worse than ever. I will show the iterations of its internals over the years and then go on with its latest rendition.
    So, here it is, what it used to be:
    Take 1:
    EVGA 680 SLI MB, E6600, EVGA 8800 GTS 512MB
Name:	Wash DC-034.jpg
    Yup, I was cool!
    Take 2:
    EVGA 680 SLI MB, E8400, 2x EVGA 8800 GTS 512 SLI
    Take 3: same as above, added water blocks for the VC's, cant find the pics
    Take 4: Asus P6T, I7-920, 2x EVGA 8800 GTS 512 SLI WC.
    Take 5: Asus P6X58Premium, I7-930, 2x GTX 460 1GB EE in SLI.
    Take 6: Asus Maximus V Formula/Thunderbolt, I7-3770K, 2x GTX 460 1GB EE in SLI.
    Take 7: Asus Maximus V Formula/Thunderbolt, I7-3770K, EVGA GTX 680 Classified
    So having gone through all these, the least common denominator was the cable management and or lack there of.
    I tried contacting TT to see if they could sell me some grommets from their newer revisions/similar cases, but they would not/could not sell me any.
    Based on another persons modding of his case, I just decided to start cutting. LOL. If you are not familiar the TT Kandalf and Armor series, they are real Steel cases. They are about 1/16" thick at least and not easy to cut through as they are steel and not aluminum.
    So I added holes for cable management/routing, underneath the motherboard on the bottom of the case. Holes on the outside of the MB on the right and top sides. And lastly, added a cutout for access to the backside of the CUP socket. A godsend as each iteration of mine from above, had to have the MB removed to even change the cooler.
    I painted the entire inside of the case in a flat black. In hind sight I would have taken a sand blaster to it to scuff the entire thing, but didn't realize how easy it is for the paint to scrape of. You will see eveidence of this all over the pictures to come, and more so towards the end. A black sharpie is going to come in handy.
    This case had USB 2.0/FW/Audio up top, but it was lacking SB 3.0. Because one of the radiators is on the front door, I wanted to eliminate having to open and close it every time I wanted to use USB3.0. Therefore I bought an add-on expansion slot USB3.0 adapter. I removed it form its expansion slot mount, cut holes for it at the top, and mounted it there, just in front of the stock USB area.
    I wanted to add some more external exhasting fan, and there is a large area on the Top that is pre-drilled/stamped to exhaust air. However you cannot get anything bigger than a 90MM fan on the underside of the top because the Power supply, disk cage and brace are in the way.
    Becasue fo theis the first bit of "ugly" is now a 140MM PWM fan on the outside top of the case. I have this running with respect to the MB temperature using Fan Xpert.
    UPDATED:10/29/12
    The First run of this after most of the mods, was with the Asus MVF , 3770K under a Swiftech Apogee XT and 1x EVGA GTX 680 Classified with a EVGA/Swiftech WB.. Both of these had their own seperate loop. The CPU LOOP on a Swiftech 655 pump on setting #4, a Bitspower 250 POM res and a Used XSPC 360 Rad in the stock DiskCage -5 1/4" bays. The GPU on the original ThermalTake 500 pump, an Aluminum Fin res. I have had for like 5 years from Microcenter, (no idea the brand) and a new slim Swiftech 360 rad to fit the front door. (All fittings are used Bitspower minus the EVGA ones on the card.)
ID:	13157Click image for larger version.
ID:	13158Click image for larger version.
ID:	13159Click image for larger version.
ID:	13160Click image for larger version.
ID:	13161Click image for larger version.
    Sry only 15 pics per post......continued below...
    Last edited by Squallalaha; 10-30-2012 at 07:49 PM. Reason: add project log to name, per rules.
    May 2012
    20
    41
    Now I realized that this setup was not optimal when/if I get a second GPU the bottoms res will be in the way. So I started more shopping and got some good deals on some more used/not needed items. I got some sleeved cables (though I swear before this I was all about function before fit/finish), A new CPU Block (Swiftech Apogee HD) and new pumps (Swiftech MCP-35x). Unfortunately the guy I got the block from forgot the stop fittings, so while looking to get new ones, I saw the 'New' Apogee Drive II, and Since I had the pumps already, I just ordered a empty block setup.
    So here we go with some of that new stuff, and getting to the current version. I didnt have any pics of the back of the Case before, and to be historically correct, I didnt want to show it with the Sleeved cables on the back, but not the front > .
ID:	13167Click image for larger version.
ID:	13168Click image for larger version.
ID:	13171Click image for larger version.
ID:	13308Click image for larger version.
ID:	13309Click image for larger version.
    11/3/12--
    more changes. new sli connectors, new/diff res., new cables
    Here is a Shot of the bottom tab from the Maingear T1000 Epic coming out from under the Apogee Drive II Block.
ID:	13446Click image for larger version.
    Replaced the old rad with another Bitspower POM, just 150 this time.:
    white PCIE cables ext., reroute the old ones, replaced the black SATA power with a 4-way white.
    Sigh, 15 pics again.
    Continued BELOW!!!!!
    http://rog.asus.com/forum/showthread...l=1#post177061
    More to come, sorry I am a slow poster apparently, gathering the pics and such..lol.
    Banned Array
    Sep 2012
    30
    635
    looking good bro, update pics after all the modding you did to it
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    199
    8,358
    Could you make some pictures also of the radiator position and reservoir/balancer? I'm curious how did you manage them...
    May 2012
    20
    41
    Updated with some progress. How does this make it to the Monthly? Section? or is it a random or voted on thing? Curious.
ID:	13521Click image for larger version.
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,112
    marshall picks it out i guess.
  7. #7
    May 2012
    20
    41
    Can vote for me at EK's competition if you like! I'm way late to the dance (started in Oct?) but gonna make a run at it! And you can see more pics that I may not have here.
    http://www.cooledpc.com/posts/view/325
  8. #8
    May 2012
    20
    41
  9. #9
    ROG Guru: Orange Belt Array Giannis996 PC Specs
    Giannis996 PC Specs
    Laptop (Model)Macbook Pro Mid 2014
    MotherboardAsus Rapage IV Extreme Black
    ProcessorIntel Core i7 4820K
    Memory (part number)32Gb Corsair Dominator Platinum 2133Mhz
    Graphics Card #1Asus GTX Titan
    Graphics Card #2Asus GTX Titan
    MonitorAsus VK278
    CPU CoolerCorsair H100i
    CaseCorsair Obsidian 750D
    Power SupplyCoolermaster V850
    Keyboard Razer Blackwidow X Chroma
    Mouse Razer Deathadder
    Headset Razer Kraken 7.1
    OS Windows 10
    Giannis996's Avatar
    Mar 2012
    12
    384
    man its awesome but be carefull with the cables dont just squize them behind the case just to have a clean build try to make them be comfortable so you dont have any issues. your doing a great job tho keep it up!
    Project Name: System Specs:
    Motherboard: Asus Rampage IV Black Edition
    Prossesor: Intel Core i7 4820k
    Graphic Card: Asus GTX Titan x2
    *Power Supply: Cooler Master V850
    Ram: 32Gb Corsair Dominator Platinum 2133Mhz
    Case: Corsair Obsidian 750D
    SSD: 2x Samsung Evo 250Gb Raid 0
    HDD: 2x Seagate Baraccuda 2TB
Tags for this Thread
