Best 140MM Fan
xNovax
I am looking for the best 140mm fan. I am looking for something that is quiet, has high airflow, and high air pressure. I am going to be using them for aircooling at first but I will be moving to watercooling soon so they have to be good at both aspects.
Rampage IV Extreme
I7 3930K @4.4 GHz
16GB G.Skill RipjawsZ @1600MHz
Quadfire MSI lightning 7970
Dual XFX 1250watt
5 REPLIES 5
ganji
ello xNovax
i use the 120mm versions of the cougar vortex fans http://www.cougar-world.com/products/fans/vortex.html which are nice n quiet and have a decent static pressure. you can also get them in 140mm however you are looking for fans for 2 different tasks. case fans = high airflow, if u want fans for water cooling (radiators then you want a higher static pressure. the corsair air series of fans are getting some really good reviews and they have 2 types in the range. high air flow and high static presure http://www.corsair.com/cpu-cooling-kits/air-series-fans.html
everybody has their own preference's with fans so you should get some more suggestions 😉
hope it helps
xNovax
Only problem with the corsair 140mm fans are that they only have one series of 140mm fans the quiet high airflow series.
Rampage IV Extreme
I7 3930K @4.4 GHz
Dual XFX 1250watt
ganji
ah sorry i did'nt realise. the cougars vortex are a good fan though and do come in black aswell if orange is'nt to your liking lol 😉
xNovax
I am also looking at these http://www.phanteksusa.com/index.php?p=products_3&id=12&cate=2 but I don't know about them for radiators because of the mounts on the fans. It says that they use 120mm mounts but are a 140mm fan. It also looks as if there are 120mm mounts and 140mm so I am very confused.
Rampage IV Extreme
I7 3930K @4.4 GHz
Dual XFX 1250watt
amuffin
This really depends on the radiator you want to use when you go into watercooling.
Tom's Hardware Expert starting fresh on the ROG Forums! :cool:
http://www.tomshardware.com/forum/profile-946176.htm
