Results 1 to 9 of 9
    ROG Member Array
    Oct 2012
    8
    Overclocking overheated! HELP!!!
    Hi,my Asus ROG Tytan CG8580 fails over clocking and leads me to BIOS and a screen of American Megatrends. This only happens when I play high performance high graphic games such as RUSE a and Shogun 2 TW.
    First,my screen displays all that red green blue screen lines then automatically shuts down,restarts and leads me to the troubleshoot black screen.In other forums before I posted here,people has said that my screen cable is loose or my GPU is fried.
    I am currently using a GTX 560 GPU.
    How to fix this?I need to use the 4.2 GHz overclock speed.
    ROG Guru: Blue Belt Array sectionate PC Specs
    sectionate PC Specs
    MotherboardAsus Crosshair V Formula
    Processor8350 - 1090T
    Memory (part number)G Skill Sniper F3-14900CL9-4GBSR
    Graphics Card #1Asus GTX660-DC2O-2GD5
    MonitorAcer GD235HZ - ViewSonic VX2439wm - SyncMaster P2350
    CPU CoolerCorsair H100i
    CaseHAF 932
    Power SupplyCorsair Professional HX850
    Mouse Zowie EC1 eVo
    OS Microsoft Windows 7 Enterprise 64bit
    sectionate's Avatar
    Feb 2012
    57
    878
    Thats called artifacting, why do you need to run your overclock speed? I'd set everything back to normal settings until you figure it out.
    Crosshair IV 1090T 4093.7 - Crosshair V FX - 8350 Batch # 1243PGT 4.422MHz - 4816.08 MHz 1.5v - GSKILL F3-14900CL9D-8GBSR(x2)1087.6 11-12-10 1.5volts - ViewSonic VX2439wm - Acer GD235HZ - SyncMaster P2350 - PowerColor Red Devil RX 480 8GBD5-3DH/OC - Current Mode: 5760 x 1080 - (retired) ASUS GTX660DC2O2GD5 - Nvidia 3D Vision Wired - HAF 932 - Corsair HX850 - Corsair H100i - latest quakelive.com - Day thirteen 60fps - as always I'm powered by Futurelooks.com
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,452
    Yes, I would reset your computer and check that the fan is working on the GPU for a start.......
    How are you overclocking...using a preset?
    ROG Member Array
    Oct 2012
    8
    Quote Originally Posted by Arne Saknussemm View Post
    Yes,it's a preset done by Asus.I just press the overclock button on my tower and it goes form 3.8-4.0-4.2 .
    Its built in.
    ROG Member Array
    Oct 2012
    8
    Quote Originally Posted by sectionate View Post
    I need to overclock to play some games.RUSE and S2TW especially. Art if acting is because the cable is loose too right? I'm on DVI plug
    Dec 2011
    354
    25,742
    The artefacts are there because your system is unstable.
    The pre-sets are not the best thing to use. It would be better to manually overclock your system.
    If you list all your hardware, include the cooling solution you use we can help you.
  7. #7
    ROG Member Array
    Oct 2012
    8
    Quote Originally Posted by HiVizMan View Post
    Where do I find my hardware in using?
  8. #8
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,112
    hes using a finished builded pc from asus.
    http://www.asus.com/Desktop/Gaming/ROG_CG8580/
  9. #9
    Dec 2011
    354
    25,742
    The tool you use to find out what your system is comprised of is called CPUz
    The first tab will tell you the CPU.
    The tab called motherboard will tell you the motherboard and the BIOS version
    The memory tab will tell you the amount and type as well as the default frequency and timings of your memory.
    Many thanks
