Bluetooth stopped working on my G53S Win 7 64 bit machine
wjhalverson
.. so I changed mouse batteries - no joy there. Then I tried to open the Bluetooth list of devices ... and it never finishes loading. So I'm pretty sure the whole Bluetooth software module is hosed. How to I re-install that? Thanks!
dstrakele
Level 14
Run Windows System File Checker to inspect and replace any corrupt Windows system files (see http://pcsupport.about.com/od/toolsofthetrade/ht/sfc-scannow.htm).
You may also need to uninstall.-reboot -reinstall your Bluetooth driver.
G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
wjhalverson
OK thanks for the good info. Will advise.
