10-23-2012 06:59 AM - last edited on 03-06-2024 07:04 PM by ROGBot
10-23-2012 09:19 AM
10-23-2012 10:19 AM
cl-scott wrote:
memtest86 tends to look for read/write errors, so if you're getting errors then you need to do the time consuming and tedious task of testing the various memory modules as well as the memory banks on the motherboard. If the RAM is bad, replace it, and if it's the motherboard that has bad memory banks you have to weigh the various options open to you.
10-23-2012 08:04 PM
10-23-2012 11:02 AM
10-23-2012 05:48 PM
