Results 1 to 7 of 7
05-25-2011 06:29 PM #1
- Join Date
- May 2010
- Reputation
- 14
- Posts
- 1,039
Best packing for inside of built Pc.
Any suggestions for proper insulation/packing materials to ship prebuilt high end pcs. Like a blown in packing material or preshaped?
05-25-2011 10:27 PM #2
xeromist PC Specs Laptop (Model) Dell Inspiron 15 7567 Motherboard MSI x470 Gaming Plus Processor AMD 2600X Memory (part number) 16GB Crucial Ballistix Elite 3600 Graphics Card #1 ASUS GTX 1080 Strix Monitor BenQ BL3200PT Storage #1 Intel 600p NVMe CPU Cooler Wraith Case custom Antec 900 Power Supply Corsair HX1000 Keyboard Logitech Orion Spark Mouse Logitech MX500 Headset Plantronics 777 with Oregon Aero upgrade
- Join Date
- Jul 2010
- Reputation
- 318
- Posts
- 7,761
Yes the kind that solidifies after leaving the can or a custom shaped insert would be best. Any loose packing would just settle/compress and be ineffective. If you're worried about a heavy heat sink or gpu then it can't afford to move even a little because a good jolt will tweak the solder connections.
* Support disease research with Folding@Home *
< < < Click the drop-down above my avatar for my PC specs!
05-26-2011 12:23 AM #3
- Join Date
- May 2010
- Reputation
- 14
- Posts
- 1,039
Very true. But where to get something like that??
05-26-2011 02:37 AM #4Brian@ASUSGuest
expanding foam in a bag: http://www.lpsind.com/InstapakCushion.htm
05-26-2011 03:02 AM #5Six Foot GingerGuest
that's what i was talking about, you will need allot them and the right sizes.
05-26-2011 01:31 PM #6
- Join Date
- May 2010
- Reputation
- 14
- Posts
- 1,039
Thanks Brian.
06-02-2011 10:41 PM #7ShadymanGuest
Be very careful with that stuff; it can put off a ton of static if it rubs things (ie a cardboard box) while being removed.
The only other concern I have with using that material inside a computer would be how you'd go about removing it when it arrives.
Similar Threads
Cooler Master V6GT CPU cooler with built-in LED strip
By ottoyu34 in forum Overclocking & TweakingReplies: 3Last Post: 03-30-2012, 01:58 PM -
Built In Web-Cam
By Relinquishedpain in forum ROG Gaming NotebooksReplies: 2Last Post: 03-04-2011, 04:40 AM -
crosshair4 extreme board socket with thermopaste inside..
By eric in forum Other Series MotherboardsReplies: 1Last Post: 02-28-2011, 06:10 PM -
My Asus built
By Gunner75 in forum Other Series MotherboardsReplies: 2Last Post: 01-20-2011, 12:01 AM
