10-25-2012 08:20 PM - last edited on 03-06-2024 10:27 PM by ROGBot
10-25-2012 10:06 PM
10-26-2012 01:10 AM
10-26-2012 02:19 PM
10-26-2012 02:21 PM
madnj wrote:
Also, having come from a G73JH with Intel 6250 wifi card, I can tell you that the Atheros in the G75 seems to work just as well.
I too have the BestBuy model, but I have no real complaints about stability with the Atheros - it never drops my connection, and my speedtests look like this:
http://www.speedtest.net/result/2267199626.png
If you are having drops, it's likely interference and should be troubleshooted by manually trying different channels on the router until you find a stable one.
Oh, and I should probably indicate that I'm about 25 feet or so from my router and through a wall.
01-05-2013 09:22 PM
01-05-2013 10:13 PM
tkolarik wrote:
OK, I have my new Intel 6325 ready to go in. One question to those that have gone before..... Which way to the ribbon cable locks clips need to be move to release those 5 ribbon cables. Close visual inspection my not be enough for me to knew, and i certainly don't want to bust one off. Or can the card holddown screws be removed without removing the ribbon cables if I had a short enough screwdriver?
Thanks!:-D
