Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    Recognized Troll Array
    Aug 2012
    21
    316
    Upgrade CPU to i7 Extreme Edition 3920xm
    Hello! I have a G75vw with the i7-3610qm
    Am I able to upgrade my CPU to the i7-3920xm Extreme Edition or i7-3940xm?
    I would post a link but I can't yet... It is Socket PGA988 just like out G75
    If not, could someone recommend the best it will take?
    Thanks
    New ROGer Array Zygomorphic's Avatar
    Mar 2012
    176
    4,761
    Here are all the relevant specs:
    http://ark.intel.com/products/71096/...up-to-3_90-GHz
    Yes, it is compatible, just the increase in heat generation will cause problems. People have tried it with the Sandy Bridge Extreme Edition (2940XM) and they had turbo-boost problems due to the 10 Watt increase in the TDP. My advice is to get the highest end non-EE model they sell. The price is a lot less, and the performance difference is nil.
    I am disturbed because I cannot break my system...found out there were others trying to cope! We have a support group on here, if your system will not break, please join!
    http://rog.asus.com/forum/group.php?groupid=16
    We now have 178 people whose systems will not break! Yippee!
    LINUX Users, we have a group!
    http://rog.asus.com/forum/group.php?groupid=23
    ROG Guru: Orange Belt Array ggBanks's Avatar
    Sep 2012
    21
    365
    I don't think it is really worth the money. And as Zygomorphic said there is a 10 watt power difference between the 3610QM and the extreme editions. The G55/75 are not made to support that much power draw from the processor, so your system will become unstable, and you may damage it as well.
    ROG Guru: White Belt Array
    Sep 2012
    85
    You need to find a cpu with 45w consuption the intel extreme edition is 55w which is causing problems also some website revomed the option of this upgrade other left it i have no idea why.
    So my guess is the Intel i7 3840qm is the best and as the previous comment the difference is not big so better safe than sorry i guess.
    http://ark.intel.com/products/70846/...up-to-3_80-GHz
    Cheers,
    Aug 2012
    21
    316
    Thanks for all the replies everyone, I'll go with the last mentioned, to match the power consumption...
    ROG Guru: Green Belt Array
    Aug 2012
    59
    597
    If your going to spend $1,000+ on a cpu buy a real laptop. For $2200 you can buy a Sager that will mop the floor with a upgraded G75 all day long. If you got that much money to waste without getting any major performance look into the Razer blade or a Macbook pro.
  7. #7
    Sep 2012
    85
    Well we were trying to advise him with the option he has, if he wanted to upgrade... It wasn't about how much money he has etc...
    And I think we answered his question but i respect your opinion and your definitely right the performance he will gain is not massive specially against the money he will spend...not forgetting the process to install it and voiding the warranty if we will do it himself.
    Cheers,
  8. #8
    ROG Guru: Green Belt Array fostert's Avatar
    Oct 2011
    54
    706
    Quote Originally Posted by BNaughty View Post
    As Stereo says above, beware that putting in a new CPU, even one with the same power rating as the 3610QM, will void your laptop's warranty. The best performance boost any laptop can get is a SSD, assuming you don't have one in there already. HDDs are the modern day bottleneck in any system, and a faster processor will only sit there longer and wait for data more from the spinning platter drive!
    G74SX-CST1-CBIL, i7 2630QM 2GHz
    32GB DDR3 RAM @1333MHz
    GTX560M 3GB DDR5 (192 bit)
    17.3" LED 1920x1080
    Sentelic TP, BIOS 203
    Debian Linux Wheezy (Testing) Kernel 3.2, NVIDIA 295.40
  9. #9
    Mar 2012
    176
    4,761
    @fostert, good point, the SSD will make the system feel way more responsive. +rep.
  10. #10
    Aug 2012
    21
    316
    I've got a Samsung 830 512GB SSD... Windows boottime is about 5 - 7 seconds... Linux is even faster... Just wanna max this baby out... 32GB RAM upgrade is next...
