Results 1 to 7 of 7
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    199
    8,358
    Thermal sensor cable and connector for hotwire
    Hello fellows,
    I was playing around lately with my GTX680 DCII TOPs... realized that actually they're pretty bad overclockers as they came out of the box (just to clarify, they're one of the best cards out there, I'm unsatisfied just with their overclockabiity)... - so, I decided that will hotwire them!
    The question I have is: May I use the thermal sensor cables with the connectors (sensor part cut off) which came with the Rampage III Extreme board?
    I never used those sensor cables, perhaps never will, and the connector fits very well on the RIVE's hotwire connector... they're pretty tin though... - that's why I'm asking if they're good for the purpose...
    Anyway, does someone knows what wiring is recommended for the hotwire thing?
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    I would use motherboard power or reset cables, I have no Idea what size wire the sensor cables are or what the minimum size needed, are you going to connect them to your motherboard or to a variable resistor? just curious
    ROG Guru: Orange Belt Array RonanC's Avatar
    Nov 2011
    29
    336
    Id use the reset type wires i sent you you want to use that gauge wire..if its too small a gauge..what if the wire came away from pcb...blown card springs to mind..play it safe
    Mar 2012
    199
    8,358
    Menthol:
    Yeah, that was my original idea too... then I saw these sensor cables and thought to ask... I will hotwire them directly to the mobo, and the sensor cable already has the two pin connector on it...
    RonanC:
    I guess, any cable/wire could be accidentally pulled off - specially in my case, as I have a TestBench (everything is in open air)...
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,452
    I think it's pretty standard from what I have seen to do as Menthol said and use MB power and reset cables......just how thin are the sensor ones you have? they are not carrying much voltage or current ... you know you have to solder off that tiny resistor too
    Mar 2012
    199
    8,358
    Yeap, have to remove the one of the resistors and and also bridge two points somewhere else...
  7. #7
    Apr 2012
    481
    13,452
    Quote Originally Posted by Zka17 View Post
    Oh really...that I hadn't read...is there a decent guide you have found out there?
