10-29-2012 08:40 PM - last edited on 03-06-2024 07:00 PM by ROGBot
10-29-2012 09:00 PM
10-30-2012 12:16 AM
justrain wrote:
Hello, I've just upgraded my laptop to Win 8 via the update program and I seem to be having problems with my computer detecting all USB peripheral drivers: according to Device Manager there's some error with
Standard Enhanced PCI to USB Host Controller
USB xHCI Compliant Host Controller
Does anyone have seen this problem?
10-30-2012 07:30 AM
justrain wrote:
10-30-2012 05:08 PM
10-30-2012 08:17 PM
10-30-2012 08:46 PM
justrain wrote:
Well, actually I did uninstall my usb drivers because the Win 8 install process prompted me that there were compatibility issues with that driver, so after the install process I tried running the USB3 Intel driver found on Intel site and a prompt appears telling me that the Intel USB 3.0 eXtensible Host Controller Driver has compatibility issues and doesn't allow to do anything with it. I did upgrade all Intel drivers that are up at the Asus download page but can't get the:
Intel 7 Series/C216 Chipset USB - 1E2d and 1E26 to work.
10-30-2012 11:26 PM
Forgottenbhs wrote:
Does your trackpad still work? If so try installing the latest INF driver from Intel website. The Win7 version should be fine, just make sure to initialize install from command prompt and use -overall and -overite (I don't exactly remember this one) commands.
